Where would I get such a crazy idea!
Fair enough. I retract that last quote. Yes, it can fail but since it can't swivel, I don't see how it can swing back and cut you.
Your diagram is difficult to understand, especially the last few steps regarding the steel inner tube and its interaction with the "blade block". I don't know what's going on with the inner tube at the end.
I think the blade is attached to a disk by two pins for some reason.
End cap comes off. Inner tube comes out of outer tube. Blade comes out of outer tube. Blade gets turned around, goes back into the outer tube and passes though some slot in a cap on the other end. Inner tube goes back in, holding the disk against the cap with the slot. Other cap goes back on, holding the inner tube against the disk.
Yes?
It can cut you if it fails. Imagine a stab. Your mechanism fails. Blade and handle form a downward vee, hand goes forward into the blade. Cut.
Okay fair enough. But that kind of injury would be a more rare occurance than if the blade was on a swivel pin where the blade is specifically designed to close on where your hand is.
What you are positing is a sever structural failure of the steel to move in a way it was never made to do from mere arm strength.
Let me me know what you think people. :thumb up:
Lock failure...ANY lock failure....involves "a sever structural failure of the steel to move in a way it was never made to do from mere arm strength."
Not to discourage you but it looks to me like you are just trying to build a better mouse trap.
We love knives, that is why we're here.
We love new knives, new designs and concepts too.
Your design seems needlessly complex to use when a simple knife would be much easier to use and arguably more efficient.
Okay, I get it. I'm the new guy and this is a little ritual forum hazing, right? Good one!
It's a blade and a couple of tubes.![]()
Still not really sure how you get the blade out of the tube to turn it around...
True. I meant the opening and closing not the entirety of it.
If only it could be designed such that the blade deploys point first out the front of the handle; maybe actuated by a button/switch.
OTF for the win...
