No disrespect, but I feel the use of ivory is in poor taste, pre-ban or otherwise.
You should see my plaid pants and white alligator shoes.![]()
That is a beauty! Very yummy ivory. Scaling the Lanny's clip to 3 3/8" is a great idea - for many patterns, that is what I consider the absolutely perfect using and carrying size - and D2 also, perfect working steel. What thickness of blade stock did you go with? 3/32"? I predict you'll have a number of orders for the Lanny Jr.
You guessed it! 3/32" I think I'll go with thinner liners next time around. These are .045 and I think .035 would be better.
That sounds like a good idea -- thinner liners are one thing that makes many of the fine antique patterns rather more graceful to my eye (and slimmer in the hand) than most custom versions of them. (Just FYI, most antique knives I've measured had scale liners of 0.022" to 0.026", with center liners of about 0.014" to 0.016".)
-- Dwight
Good to know, thanks Dwight. Aren't most of the thinner liners crimped in some way?
They typically used a rounded crosspein hammer (or something that produced similar results) and would hammer the scale side of the liner in a line, normally between the two end scale pins (avoiding the scale or shield pin holes - so sometimes you'll see several slightly offset strikes used instead) -- this "stretched" the liner along a center line, which cupped the liner a little. When the scales were pinned on, this cup would cause the liner to seat/seal down tight against the scale all around with no glue required, even if the handle profile was further ground after pinning the scales, and it'd stay that way too.
Have you, or anyone you know, ever attempted to reproduce this process?
