I had a thought. It almost died of loneliness. Here it is.
Problem: How to "sand" the bevels without rounding the ridge? First and most obvious answer was to use sanding boards. I started off with that, but in my implementation the paper is never drawn taut enough on the board to insure it stays perfectly level.
What I wanted was something flat, hard, and abrasive, but wouldn't leave gouges.
I thought about it and remembered I had a 3 piece set of sharpening stones from Harbor Freight. When used with the broad side, they form a flat even abrasive surface of either 100 grit, 260 grit or 600 grit. I starting using one and found that the bevels that I thought were already flat were a bit convex. Not surprising, since I ground them by hand. Slowly but surely the stone is reveling the problems with the bevels... and working them out.
I'll post some pictures later this week... when I have time to take some in daylight.
