I am finding the rope will dull the blades much faster than cardboard sofar.
I sure hope so. My cardboard cutting tests leave me with sore fingers and piles of cardboard. It makes me wonder how cardboard got such a reputation for being so hard on an edge. With few exceptions, any steel I've tried on cardboard will cut for a long time before it dulls to the point of not being able to cut a piece of paper. This is my lower limit for useful cutting ability. If I can't slice paper, the knife won't cut much of anything else with any degree of control. Loss of control = time to sharpen. I've cut over 20 yards of cardboard on the same 1" of blade on AUS-6 and the edge would still take hair off my arm.
Carry on Ankerson. One of the issues with testing edge retention is the lack of accepted standard cutting material. Rope works for a lot of people, though I've not been able to get consistent results with it.
Agree. Even testing a D4/E4 ZDP-189 against the Caly3 would be apples and oranges, or as you put it better, testing the knife as a whole rather than the steel.
The only platform that easily allows a real comparison of steel to steel is the Spyderco Mule project, and that has a bunch of limitations (range of steels in the program; specific hardness chosen; etc.)
... What you found out is that a variety of knives sharpened the same will cut a lot differently. ...We tend to say like you did that the ZDP 189 knife cut the best so therefore it is the best steel. In that particular test in your hands, with that sharpening and that handle configuration, hardness, edge and edge profile, cutting that sample of carboard on that day on the basis of one test it was the best. I am not being critical of your testing, just trying to put it all in perspective.
I like to cut manila rope just because you get faster dulling and it tends to show up larger differences quicker. With the exact same knife configuration but with different steels it is still difficult to see small differences. For example I recently did some comparison tests with CPM S110V, CPM 10v, and CPM M4 all at the same hardness and there were no large differences like-- one blade cut 100 more cuts than another. For this reason I would say that they are in the same category. The differences lie in other areas like corrosion resistance and relative toughness and sharpening ability ... blade thickness and grind geometry make a huge difference in cutting performance. Heat treating as well. I recently compared CPM S110V at RC 60 to CPM S110V at RC 64. They act like different steels. Also you can heat treat the same steel to different objectives. CPM 154 is a good example. Using the lower tempering range emphasizes corrosion resistance and toughness while the higher range hardness and wear resistance. I admire you for doing some testing and even more for putting the results out there. It is all good information but I guess what I am saying is that we have to be careful testing knives and coming to some conclusions on realative performance of knife steels. Phil
I don't consider myself an amateur on steels and edges, but when Phil Wilson speaks, I listen.
sal
sal
