- Nov 19, 2008
Discovered a minor issue with my 0770cf...after using it as my edc over my 350 for almost a week, I cut my hand at the base of my thumb while reaching into my pocket to get it out...the space between the scales is enough for that part of my hand to slip between the scales and get nicked by the tip...after this happend, I took the tip of my index finger and ran it across it and sure enough I can feel the tip...
I think it has more to do with the blade design then anything...
Thoughts?
Pretty common on some slipjoints. The fix for those is to sand down the kick a little. For modern knives you just need to find the part of the blade that hits the pin which stops the blade from hitting the back spacer and sand a little off the blade where they touch. I do mean a little, just using a medium grip sharpmaker rod works great.
Or you can get KAI to look at it, I'm sure they'll take care of you.
