- Nov 18, 2007
I just got my new forge all finished up and running. It is a thousand percent improvement over my old N.C. Knifemaker forge. I am running 2 1/2 lbs of propane pressure and getting 2380 degrees. It went from room temp to 2000 degrees in 4 min.
It measures in at 16" diameter on the body and 18" deep. It has a double 1" kaowool lining. And a bottom of 2 layers of 1 1/4" firebrick with a piece of 1/2" kaowool sandwiched in the middle.
My buddy Dave over at H20 Waterjet & Fabrication cut the parts and helped me with the fab work on the body.
We built this forge a bit different than most of the ones I have seen. We split the bottom of the pipe and welded a 2 1/2" bottom foot all the way around. That gave some extra depth for the bottom and allowed everything to sit flat. We also welded a band around the front and rear plate. The rear plate is welded in solid. But, the front plate is held on with removable pins so that it can be taken off for re-lining.
I want to thank everyone who have so freely shared their forge building info. It really helped me with this project.
