- Sep 6, 2014
Well, I finally broke down and bought a new saw for the shop. It's the Milwaukee Portaband 6232-21 with a Swag off road table. It will be replacing my Jet 5" x 6" horizontal/vertical bandsaw I've had for that past 15 years. The Jet has been a fairly decent saw it was just slow going when it came to sawing out blades, I had an economy model 5" x 6" horizontal/vertical saw I bought a few years earlier from Menards that I managed to burn up in about 3 years before I bought the Jet. Anyhow I put the saw and table together last night with a new Lenox 14 TPI bi-metal blade and tried it out, the new saw cuts least 3-4 times as fast as the Jet. I can push a 5/32" piece of cpm154 through it with a push stick with zero hesitation, it doesn't slow down a bit, not even on lowest variable speed setting. Speaking of variable speed, that is feature I'm glad I opted for with the new saw lower speed with a finer tooth blade for thin spacers and handle materials. The variable speed rating for the saw is 0-380 fpm or depending on what resource you looking at 420 fpm no load speed. What I found when playing around with it is its low speed setting is probably around 150-200 fpm and the high speed setting is probably about what it's rated at anywhere form 380-420 fpm. At any speed setting it should easily cut through any blade stock that I use in my shop, but on the high speed setting the work piece can get a little warm when making longer cuts, meaning if you cut the entire profile knife blank out you're probably going to have to wear gloves or dip it in water. I tried the saw on a 1/4" x 2" piece of angle iron and cut through that in pretty short order. Also pretty nice is it comes with a limited 5 year warranty. The only thing I don't like is, it's very loud, noise doesn't generally bother me but with this machine I think I'm going to be getting some hearing protection, worth it for the time it will save me. And lastly I will be building a stand for it. Anyhow not sure what to do with the old saw, probably put in the top of my shop and maybe re-power it down the road, it came with a 1/2 hp 1720 rpm motor and has 3 speeds 80,120 & 200, I will keep my eye out for a used 1 hp 3450 rpm motor to try on it, that should get it to where it needs to be power and speed wise.
The new saw.
The old saw.
The new saw.
The old saw.
