- Oct 28, 2007
just to clear things up the toaster didnt break it the heat did. any heat "thing" would of broke it if cold water was dripped on after words
It does. Just wanted to make sure.
I think you could probably heat it to fuse/melt it back together. Anyone?
don't heat kydex less you now whats up to much heat will make it brittle. i would make a sheath for you for free if i can come up with the skel warden. i will try to get a hold of D F Hog he might have one so i can get a pattern.
personally I would do what Dwayne suggested and just send it back
but
I will remake it for ya if ya send the skelly with it ( and tell me I'M pretty)
i dont have to tell my mom i am sending my knife to "some guy"![]()
Drill a hole at the end of the crack, fill the crack with glue then use a thin strip of Kydex or other suitably tough cloth/material to wrap either around the sheath or inline with the crack. Then use some more glue on this material so it becomes bonded to the sheath. Sort of like carbonfibre or fibreglass construction? Would over-strengthen the area of the crack so that it didn't simply continue to split at the end of the crack. The hole allows the end of the crack to stablize, it's a technique used in bell repairs.
Ya the methylene chloride ideas probably not the best idea![]()
