Is that Canadian Bacon(you may not call it that) fat?
Ha! I mix it with Canadian Club Rye Whiskey and a dash of Canada Dry ginger ale to get the exact blend.
To answer the OPs question the CRK grease is the way to go. I've tried a lot of things, but have decided it works the best for these reasons:
1-the carrier fluid evaporates and leaves the flouro-film behind so it doesn't attract lint or run out of the pivot.
2-the CRK grease is food-safe
3-the price is reasonable if you need to buy it (when compared to similar volumes of the Cristolube dive cylinder grease that CRK is repackaging). I've never needed to buy any mind you.
4- it doesn't smell
5- it is waterproof (designed for the diving industry). I wash my knife in the sink every day. The CRK grease stays put.
6-it is temperature stable (I often use my knife, outdoors, in very cold weather.....since it's not an "oil", it doesn't change viscousity and get harder to open)
7-you get pretty much a lifetime supply if you buy a CRK new.
8-the grease is designed to prevent galling and corrosion between dissimilar metals, so I don't have any concerns the different metals of the washers, pivot, and blade are going to affect each other.
CRK grease all-the-way for me.
