I am sticking with the finish line extreme.... once you try it you won't go back to the crk grease
I've had good luck with Nano Oil. For CRK I use the 85 weight oil, or a combination of the 85 weight and 10 weight oil. YMMV.
I have used and tested this extensively for the past 6 months. It's pretty good if you are always using the knife, it does dry out in a month or so if you don't use the knife regularly. Stopped using it on my safe queens.
i last applied finish line extreme to my seb 21 in july of 2016 and the blade still opens and closes smooth as silk... that wasn't the case with the grease supplied from CRK
Lets settle this right now!!!
90% of the time I carry a small CRK Insingo as my (heavily used) EDC. Polished the washers and the action is very nice. The fist year and a half I used the CRK grease and found that it ran dry after about 2 to 3 month max. Taking apart the knife in theses intervals always showed completely dry washers. Then two years ago I discovered the Nano Oil Grease and started to use that on most of my knives (washers and ball bearing knives a like). Now I find that my Insingo stays lubed for about double the time then it did with the CRK grease. When I take it apart every two to three month it always still has some grease in the "chambers" of the washers. I can't say I notice a difference in the action between the CRK grease and the Nano Grease (both give extremely smooth action with the polished washers) but the Nano Grease seems to last longer.
I DON'T LIKE THE PERFORATED WASHERS ON THE SEBENZAS!
I also have the same experience as some with the CRK grease drying out inside the perforated washers. I have been using Mil-tec grease with better and longer results.
Now the old style washers are a whole other deal.. I find them smoother and they don't need anything but a flim of oil. Even dry they run like they are on glass. That is why I like the older Sebenzas.. wish they would bring back the old washers and get rid of the perforated ones with the holes.
but i really like the hypodermic needle applicator from finish line...[/QUOTE said:CRK's used to come with those
