Thank you very much for the reply. I wasn’t implying any ill intent if that is how it came across. I assumed it would be 20 DPS since that is your normal angle for these and I figured you did just that pull it out of the pile so to speak. Just didn’t want to make an assumption without knowing just going by my hunch.No, it wasn't. It was 20. Our standard angle is 20 for that pattern and I pulled it from a stack. Not a valid scientific test, but I didn't want to end the video on a down note and it was an impromptu cut. I was demonstrating Magna cut against some carbon steels and broke it on some bolts and I wanted to end the video on a good cut.
And then, there was a little brouhaha about cutting a chain a while back. That chain was included in a lot of grinders that I bought at an auction with an unknown background that was clean and not rusty and people, both on blade forums and Instagram, accused me of cutting aluminum or lead. So I wanted to show a rusty chain cut. I've had it sitting out in the rain for a while.
It was not a perfect demonstration but I did not enter it with the intent of misleading anyone, but these knives are normally 20 DPS. I reduced the angle to 18 for development work because it makes issues with edge stability more obvious. Delta 3V can cut a bolt or a chain at 18 DPS without blowing out. There will be a little more edge damage but it is not some kind of a threshold where things start just blowing out because the angle is a couple degrees narrower.
A flaw in the demonstration due to poor planning, not some nefarious intent.
I like hearing about angles, as the question is at what angle edge can it get through a nail, as a I think a random butter knife gets through a nail at around 30 degrees without damage.
There's a video out there. it's about 30 degrees, grinds it, buffs it, cuts nail, shits on the nail test, I don't want to post it, because I worry it will give the wrong idea to the people who just skim and watch the video. But the point is that it's gets very tough to cut a nail as the edge gets thinner, and as a fan and owner of your knives, they have nice thin edges. So thank you.I dunno. You should try it.
I sharpen my fixed blades to 15 to 17 dps. There are some (scandi grinds) even with 10dps. I like my cuts to be effortless and I do not mind using them carefully.
My CPKs had no use yet and they are still possessing the intendent edge angles. But I have a feeling that they would hold up great at lower angles if they are not abused heavily.
I am not planning to go with very acute (<15dps) on my CPKs. I only do that with my slipjoint knives. I usually go 15 or lower (often 12.5) with these due the way I am using them. Probably I will keep most of my CPKs at original geometry (particularly the behemother) as they are meant to be hard use knives, even though I am not some using his knives in that way. I would take my MC DEK3 to 15dps when it comes.I would say that 15 DPS is the basement. Narrower than that and I would find a different steel such as AEBL, and the higher carbon simple steels such as 52100 and W2 etc.
I have 52100 kitchen petty knife which chips easily... It is not particularly thin either (it is 17 dps with around 10tho behind the edge). Probably a heat treatment issue...
Resulting with carbide growth?52100 can put too much carbon into solution if the aus time or temperature is too high, and it does not have much carbide pinning grain boundary.
Not carbide growth but grain growth. The carbides that pin the grain boundaries are not particularly robust (they dissolve and disappear) and massive grain growth from excessive or repeated heats can create a fragile matrix. Or, you can simply put too much carbon in solution. You can temper that back, but it's better to put the optimal amount to start with. Many materials perform well with a little bit of lath mixed in with the plate martensite. 52100 has fantastic properties if done just right, but I don't think it is as simple as baking brownies. That stuff is above my pay grade.Resulting with carbide growth?
Thanks for the interesting info.
That'sThe metallurgy nerds here might like to follow triplebhandmade on IG. He has gotten deep into sharpening techniques vs steel types, BESS sharpness, vanadium carbides, micrographs and other neat stuff. Always learning.
I believe soThat'sDeadboxHero on BF, right ?
Yes.That'sDeadboxHero on BF, right ?
Yes.WTF is even going on r.n. ?
