lambertiana
- Jul 7, 2000
You only need three things:
Bamboo (found everywhere)
Nipa palm (found in swampy areas everywhere)
Abaca, the source of manila hemp (sorry I couldn't get any pictures in the field, it is found scattered around, but not terribly plentiful)
Start by cutting abaca and pounding out the stems to retrieve fiber to make cordage. Then cut bamboo for poles, and also cut a lot of bamboo into strips. Some strips need to be 1", others need to be 1/2" wide, others only 1/16" or less. Cut nipa fronds. Now the work starts.
Build the frame with bamboo poles. The corners are connected by inserting pins and lashing together at the ends (sorry I couldn't get a closeup of natural fiber for the lashing):
Put in flooring over the frame, using the 1" bamboo strips, and weave the 1/2" bamboo into the siding
Then sew together nipa fronds with the thin bamboo strips, and attach them to the frame for the roof using bamboo strips:
When you are done, it should look something like this
