Ditch the pull through sharpener. It will ruin a knife you buy and never get anything really sharp. As for serrated or plain edge? Well thats debatable and youll get many different answers. If you know how to cut with a serrated blade then it will benifit you to buy one other wise stick with a plain edge.
I would go no serrations. In my opinion, a knife should either be full serrated or fully non serrated. Serrations are great if you are sawing things but if it is mostly clothing and things of that nature a non serrated would probably be better as they wont snag on the clothes. Serrations do not need to be sharpened very much if at all but it is much easier to sharpen a non serrated blade. I would go with a Benchmade Auto Triage. It uses an N680 blade that has a blunted tip (for rescue type work, as not to stick anyone when cutting off clothes) which is very corrosion resistant. It is also easy to sharpen and maintain. You may also purchase a strop of some kind (the Flexx Pocket Strop would be perfect) so you don't always have to sharpen. Once you get back Benchmade has the best customer service in the business and you can send it in and they will fully clean and service it for free for life. That is my opinion anyways.
I don't have any brilliant insight with regard to to the plain vs serrated debate (although I haven't carried a serrated blade in almost 20 years, which should give you some idea where I fall on that issue), but I do question the use of an auto. More moving parts to clog up with dirt, sand, or blood in circumstances that may make regular maintenance difficult. Not to mention that in many locales automatics are always seen as weapons, which means an auto may not even make it through customs at your destination.
Were I you, I think I'd be looking at a smallish fixed blade. If you do decide to go serrated, Spyderco makes a serrated sheepsfoot version of its Enuff fixed blade which might be ideal. Otherwise, it also makes two non-serrated variants of the Enuff. All available for just a bit over $100.
And I applaud your service. DWB is an outstanding organization. :thumbup:
Whatever knife you get, ditch that dinky sharpening thing and take something better. For travels, I'd say get an edge pro knockoff from ebay for $20 and upgrade the stones.
They function well, work quick, pack easily, don't weigh anything and will make you a rockstar to anyone else there with a blade.
Buy a real one for home of course.
Im new to the knife world and dont have much experience so i need some advice on whether to get a serrated vs regular edge knife and the pros/cons of each. My situation/needs are that Im headed to Africa for Docs without borders and I need an EDC (every day CUTTER, cause im not just gonna be carrying it). Outside of the normal every day tasks everyone uses their folder for, im will most likely be cutting clothes off and cutting tourniquets in emergent cases. im gonna be using this instead of the ugly and bulky medical shears you always see med profs using. its gonna be an auto because that will be easier to handle with gloves on that could possibly be bloody and/or ill-fitting. I know serrated are more difficult to sharpen and i going to need it to be super sharp, i actually bought the sharpener in the picture (this is my first post so i dont know how its going to show up) for said task as i wont be able to have someone else do it while im there. So knowing what ill be using it for and that ill have to sharpen it myself, what does everyone think i should get? regular or serrated? i appreciate guys, yalls advice is much appreciated
Where would I get a replacement stone and what kinds? Would you be able to send me links of what exactly you think i should buy? I already spent $20 on what is apparently a piece of shit pull thru and i dont want to waste anymore money. man, the things ive had to spend money on for this freaking trip are bleeding me dry. even though med school put me over $200K in the whole with loans i was able to completely pay off all my unsecured debt like credits cards and lines of credit but this little excursion has caused me to dip back into my one emergency credit card i left myself, its so annnoying
For what you will be doing, a knife with serrations is absolutely the best way to go.
Not all serrations are equally effective, so you should look into which type/style of serration works the best. (Can't help there, I don't have enough knives with serrations)
That sharpener you bought it not the best idea.
I am not going to get specific, you can research the reason, but you would be much better off with a simple stone/rod system.
Yes, you will have to learn how to use it, but It's well worth it.
Frankly, I would go with a Leatherman Charge TTi. Most of Africa is broken so everything needs fixing. The Charge has both straight and serrated blades plus a few more like needle nosed pliers... scissors too.
If you want more then a Spyderco straight edge too for front pocket as your private EDC.
An Auto will just get broken, gunked up. I always say the time it takes to open a folding knife is thinking time to how to get the job done efficiently and safely. (If something is pumping juice then put your knee on it, while you think WTF, and work out what has to be done).
A Smiths 3 in 1 Sharpeniing system has all the sharpening stuff you need and isn't too expensive. Or a DMT Diafold (blue/red) and a lether strop with chrome paste.
Last thing for Africa, don't pack too much, just what you need. Nothing flashy or expensive. Big dufflebag and a daysack. A filter bottle system is a good thing to pack too (look at Grayl and Aquamira (viral)).
Any of these combos offers different styles of edges, of serrations, of sizes, shapes, and an incredible wide array of implements and abilities to perform almost any task. All together, less than $80.
