Need help choosing a knife for work
I'd go ZDP Delica and slipjoint it for easier onehandability. For cutting cardboard en masse maybe a endura or stretch would be nice(haven't handled either but guessing they're just as nice as the delica). You may also want to look at the DPx H.I.T Cutter; S35VN, easy one hand operation, don't need to lay it down when grabbing/moving stuff
Just impulse bought a para 3 in s 30v haha. I was about to get a sheepsfoot g-10 mini grip but I felt my friends grip and theres side to side play in the axis lock. If i dont like it i will return it for possibly a emerson or wharncliffe delica, im just a weirdo when it comes to those molded plastic scales so i went with the para 3, thanks everyone!
C
Can't go wrong with a Para.
How is it that a guy can post asking for recommendations for a "pocket knife (not a box cutter ;))" and people will still recommend that he buy a box cutter?
Oh, he should get a pocket knife, too. But he should invest the $5-$10 in a good box cutter, which is, of course, a pocket knife purpose designed for the task he has to do regularly.
This. Then go with a Mini Grip g-10 or a Para 3 (fits the 2.5-3” blade).
Good utility knife with replaceable blades.
That's what I used when I did that.
YUUUUUP !
There is wisdom here.
AND
you can even get "Carbide" blades for the box knife. I just use the standard Stanelys and they are thinner than regular "Heavy Duty" so they cut faster through cardboard. The heavy duties are for construction work.
I don't use the carbide blades much though I have a knife with those in it with me every day. I just sharpen the regular blades on a Spyderco Ceramic triangle stick. Partly because I even reprofile my box knife blades (knock the cornice off the factory blades and polish the sides). NOTHING can out cut these for boxes.
Doesn't mean you can't EDC a nice knife but I don't like what box grit and box tape does to my nice knives.
If you don't want to go with a box knife you might look at a Spyderco Chaparral in one of the super steels. The Chaparral is thinner than most and that is what counts in a box knife. And most of the rest of the cutting I do. Thin is in. Thin is the ticket.
PS: The Chaparral is a back lock. I pulled out and put away a back lock a whole bunch today (a Spyderco Endura 4 ZDP-189). Just takes some practice to one hand it. Admittedly not as fun as my Para 2 or Benchmade 940 but I love the Endura and I needed the length for the work I was doing today.
The Para 3 looks like great knife! I just got a Mini Grip G-10 (555-1) yesterday and the lockup is perfect. No blade play and feels great in my hand. Looks like the Para 3 should suit your needs though.
Look at a Benchmade 485 Valet.. great steel, small, easy opening/closing, good lock, good company
Welp, I'm late to the party.. Enjoy the para 3 though
My 2 cents, and again new into knives.
When I worked at a grocery store, it seemed like visibly expensive items caused problems, or could become targets for theft. While I didn't have a lot of money at the time, I had gotten a $500 citizen watch that drew attention, sometimes not the right type. It got beat up and eventually I stopped wearing it and switched to a cheap timex at the store.
We also had one of the Chef's, yes this store actually had Chef's, with a nice $500 set of personal Global knives.... I think he brought them in for a total of 2 months. However, others started quickly using and abusing them, and he went back to the store provided Mercer and other random NSF knives. Even stealing his crappy NSF knives became a habit for many as they were at least sharp. I used to keep a Chefs knife and pairing knife hidden, and had one of the butchers teach me out to sharpen them.
I worked at UPS for a while too, and I recall most people using folding box cutters, which were needed from time to time. I seem to remember a few people who had nicer knives, but in my limited time there, imho it could draw attention that wasn't really what i would perceive as good.
So I guess my advice would be, keep the amazing para3 for when you want something nice.
At work, use a functional tool that you don't care about, or you can afford to easily replace, because it will get beat up, broken, stolen or lost at some point. Personally I would recommend the Kershaw 3/4 ton, for $15 you can't kill it, it will keep a decent edge, you can use it to pry on things, and its easy to sharpen. I just bought a Native 5 to replace the 3/4 ton (given to a friend), but I really don't think its better, and the Native 5 may be worse many of the most frequent times where I previously used the 3/4 ton.
Best knife for the job is a simple replacable razor bladed box cutter utility knife.
But if you feel the need to use a comventional knife ... you have two choices to make first in my mind ...
do you want one with a decent steel that gets very sharp and is easy to resharpen to that very nice edge? ...
or do you want to buy one with a newer harder more wear resistant knife that will hold its edge well much longer but if you arent comfortable sharpening that harder steel ... it may take you so long to get a decent edge back on it that you wish that razor blade utility knife were in your pocket.
Yeah box cutters aren't as cool as a nice knife with a new "super steel" like ... M390 or CPM SV110 or CPM M4 ... but they have their place and for their job they definately are by far the best tool for the job.
Just MHO
Speaking as someone who formerly had your job and also used knives I can say that a Delica will do the trick. It is, however, not as easy to whip out or away as a liner/framelock knife. Also, serrated edge is great for cutting grocery packaging (cardboard, thick plastic, etc.).
Something truly useful would be a small fixed blade or an actual box cutter with inserted blades, but they each have drawbacks compared to a nice folder.
Just noticed your aversion to the FRN on the Delica. I also dislike the Spydie FRN, but honestly your in an environment where loss or theft of your knife has much potential, and its main use is to eat cardboard. I personally preferred my FRN handled knives for that type of work, and carried my nicer ones elsewhere. That said I also noticed you went for the Para 3, never held one but I imagine it will be great for this type of work!
Can't agree more. Used a 3/4 ton when I did this work it is a great slicer, smoother then I had imagined it would be. It is a rather wide blade though and I scared a few customers, but management never received complaints.
