I have a feeling that my next order from HH is going to be much more expensive than my previous ones. I wish they sold an assortment or 1/2 pound increments because I'll probably be buying a pound each of small/medium/large wedges at this rate... in addition to ten-ish handles.
It isn't needed even on your first hang. I've never used a metal wedge including the first axe I rehafted. I have however pulled a number of metal wedges out and can attest that it is a royal PITA.
Fourth from the left in this picture. The two with metal wedges in the picture are factory hangs. And one of them I just went through the PITA of removing the two wedges since the factory haft failed. Honestly I would just wedge the thing and start using it.
Seeing photos like that makes me thing that either I'm not as crazy as I think I am... or that others are as crazy as me
I got really lucky, the boy's axe I pictured in my on/off topic help/id thread:
http://www.bladeforums.com/forums/s...ic-Help-amp-Identification-(lots-of-pictures) had two metal wedges way down in there surrounded by three nails (only one is pictured, the other two I had already pulled). I got lucky because I was able to pull the nails and then start using the axe for a few chops/splits and the head quickly came loose. With the persuasion of a wooden mallet and a dead blow hammer, the head slid right off the haft making it much easier to pull those pita metal wedges. I'm not sure I'll ever want to use a metal wedge after that experience but I wasn't sure as the forum seems divided on the subject. If HH sells metal wedges by the pound they can't be that bad can they?
I now have about 40 (yes forty) various heads (hatchets, axes, mauls, sledges and about 20 hammer heads) that need handles. Do the purists think there are any appropriate places to use metal wedges or wooden only?
No it's not that important because the wedge really only applies pressure left and right (so to speak), and less front to back. However, I DID rip most of my own early handles out, so you might as well plan on your early work not being good enough if that's the sort of person you are and obviously, I can relate. But there's nothing wrong with that. It's good practice and the process of pulling your own handles will tell you a lot about how well you hung them.
It is an interesting process to pull handles. I've now pulled ten or so and often find myself shaking my head muttering wtf under my breath. Even more interesting is I didn't hang any of them, most of them were broken factory handles or things other family members had done. Part of me wishes I had waited a little while to pull them because to be honest I'm just tearing the wood out without really knowing what to look for so I'm not sure it is as much of a learning process as it could be. And seeing that someone in my family shoved a haft into the eye of that boy's axe that was way too small, had no kerf wedge, and then just shoved as many metal wedges and nails as possible into the top of the eye was about as funny as it was wtf...
To add to the lack of learning process, with the exception of the boy's axe haft, all of the handles I've pulled have been 50+ years old, broken and not reusable in any way, and extremely cracked and dried out so the wood just falls apart.
