Esav Benyamin
MidniteSuperMod
- Apr 6, 2000
Enough with the paper wheels. Let's not hijack a perfectly good thread on using stones.
I have some rougher diamond stones I use if something is damaged but that rarely happens.
Refinement is where I am at. I should probably just order the Edgepro and shut up about it.
I'd love a set of diamond stones from DMT, but damn they're expensive!
http://www.woodcraft.com/Family/2000226/2000226.aspx
Hi dsmegst,
I was pricing an entry level kit which would only get me started. My idea of a full set was based on the Naniwa 220, 400, 800, 1000, 2K, 3K, 5K, 8K, 10K, 12K individual stones which I have only priced once so far. It is possible there are less expensive stores, but my total in US dollars before tax or shipping was going to be $606.65.
That did not include a handy adjustable foot plate, flatening stones, or abrasive grit for the flattening stones. Would that be necessary, I would guess not, but I would probably end up buying them anyway.
Doug
I agree with KennyB. Go for strops now and see what they can do for you. Anything else is more of the same, even if "better" it's still grinding, whether manually or guided. For some kinds of edges, waterstones are good but strops are a big boost for everyday use, sort of like a Sharpmaker: won't do everything, but perfect for what it does do.
Well, that's not exactly what I was imagining. My grit steps are much more spaced out then yours. The difference between say 1K, 2K, 3K isn't really that much as far as I know. So I go from 1K to 4K. I never looked into going past 8K since that's where a strop would come in.
If I tried all those grits, I know I would screw up somewhere and have to start over.![]()
Yeah, Norton makes a combination set with two combo stones and a flattener for somewhere around $150. The stones are 220/1K and 4K/8K. I don't think that Norton actually makes natural water-stones though, I'm pretty sure they're synthetics. Either way, the 220/1K is all I use as far as bench stones go, and it does a pretty good job. I've only really been curious to try the 4K/8K, and their stones are a little bit expensive so I've just been finishing edges up with chromium oxide after their 1K and they're plenty sharp for me. Shaving sharp at least.
cbwx34,
Because he mentioned wanting to get another stone for refinement, but he could probably get way much cheaper with some diamond paste or some of the various other 9-1 micron compounds before stropping on leather and chromium oxide.
@pwet
When you say "shave" do you mean, shave like this?
http://www.youtube.com/watch?v=Ksn0tjpH5_8&feature=related
I have not done a lot of research on waterstones, but the impression I get is that you would soon far exceed the cost of an edgepro before you had a full "set" of quality waterstones.
almost.
shaving your face with a 1k edge is painfull. even stropped. but at 0,8-2k (the stone used for the actual sharpening before polishing, two different actions) you should already be able to remove full patches of arms hair smoothly with one pass. if you see what i mean. if you don't and you move to 4k you are trying to improve an edge that's flawed at the start and theres no way you end with a good edge.
4k edge sould bite your skin at the slightest movement of your finger on the edge, if it doesn't you have either rounded it or never got it. also you should constantly check your edge, after each abrasive : the 800 stone, the leather, the 4k, the leather etc.
I don't know, I think it's probably got a lot to do with subjectivity, but my edges stropped on CrO after my 1K Norton shave my face without pain. They don't feel like a straight-razor would, but they actually feel a little better than the store-bought disosable ones--probably because there's not blades on my face.
Anyway, my point is that when I run my finger down those edges that shave just fine, they don't bite at my finger like they would if I just left it at 1000, but at the same time if I just leave them at 1000 they won't shave as well. What's up with that?
I think I'm just as confused as the OP now.
you have to find a sharpness test that works for you i think.
I have never tried cutting cheese with either my kukhuri or a guitar B string but I think the high E would work better![]()
Sorry, I don't like dull knives.
cbwx34,
