- Nov 27, 2002
Where are you...? There might be someone nearby that has some
extra stuff....
extra stuff....
Yes, we are similar in our limitations is seems. I also thought about building the rolling mill. They seem simple but buying all the bearings, sprockets, chain, and electric motor, not to mention the steel, would get pricey i think. I had an idea about using some old trailer hubs that i had from a scrap pile, and either weld them to schedule 80 pipe (i think thats right), or maybe bolting break drums to them and use that for the rollers. However i would still need the motor, sprockets/chain, and the steel frame and other components. Maybe one day i'll try to build one. Maybe i'll even buy new parts instead of using scrap. I dunno. THe press seems more do-able right now.
I hope I'm not hijacking this thread. Recent circumstances (my lawyer effing up the release of the full lien funds on my house from 6 years ago means I won't be buying a press) have me planning a press build right now. I will have some funds in the next 10 days and will be shopping shortly thereafter.
For the experienced press users, what would you recommend in the build once, cry once scenario? The Bateson press is 24 tons, 8" stroke. I can get a 34 ton 5" cylinder with a 24" stroke for about 350-400. Is that length needed, if I get into feather patterns and such? http://www.princessauto.com/en/detail/5-in-bore-x-24-in-stroke-log-splitter-cylinder/A-p8401135e
Is an H frame or C frame recommended? I was thinking of using 4140 for the dies. Is there a better option?
As the owner of a C frame, I would recommend an H frame with a die plate and holder system that doesn't require a lot of tight tolerances. With either type, you can align and weld the dies to the plates on the press. Weld the top die up on the bench and then install it. Position and tack weld the bottom die and then finish it up on the bench. Ladder dies are easy because they happen to fit together in the inner you require.
extra stuff....
Machining the rollers and welding up the rest is where is gets complicated. Building a press involved cutting and welding and running the lines. That seems a LITTLE less involved.
poor boy since you are in Akron the first piece of advice I will give you is to shelf the air press idea and use some of that $300 to buy a membership with SOFA. They are a large blacksmithing organization full of great people that are very helpful and they have a massive shop with forges, anvils, power hammers and of course a press. They put on blacksmithing and bladesmithing events that draw people in from all over the country and even further. And you can go there outside events every Wednesday and forge to your hearts content while learning with other new smiths under guidance from there very helpful staff, one of which is a JS in the ABS, all for the cost of your membership.
I can absolutely understand the desire to have some kind of press, I have that same desire. But there is no need to rush into it and I can assure you, having been through this process, whatever you think a bottle jack press is going to cost you it will likely be a lot more. And honestly until you can afford a real press I would just buy bar stock of quality steel and save the leaf springs for building fixtures, work holders, welding tables, etc. You can never have enough scrap steel for projects. $100 will buy you lots of 1075, 1084 or 5160 all of which you can forge, grind and heat treat with what you have!
Good luck and if you buy a membership let me know. There will be an ABS hammer-in in August and the Quadstate Blacksmithing conference in September. I'll be at both and would be happy to say hi and offer you any help I can provide.
-Clint
-Clint
I will just say that if you could make a working press for $71/$89 and some scrap steel there would be hundreds of tutorials on how to them on the internet. The fact that no knifemaker or blacksmith that I or most of the people here know has one is another proof of how poor the idea is.
Ask yourself, "Why would thousands of people who are knowledgeable on smiting as well as building equipment spend a coupe thousand dollars if it would work for 1/10 that?"
Fill out your profile so we know a bit about you and stick around. There is a lot of good info and advice here. Knowing your age, occupation, interests, and location could get you some great help in a build or offer to come use a near by makers equipment. I would also really consider making a visit to a SOFA meeting or event. If nothing else, you will meet a lot of potential networking people.
You know, the best bet for you might be to keep your eye out for a deal on an old hydraulic log splitter. It's basically the same thing as a forging press, you'll just have to modify the "die" area, and then forge on the horizontal. Lots of guys have done it.
Used they go for like $800 around here if in decent shape, BUT- I scored one that worked fine and just needed a tiny bit of TLC at the local junkyard, for $300. It would have made a fine press, but I sent it to my folks to split wood with.
Do you have a local junkyard? You should go there anyway.
poor boy since you are in Akron the first piece of advice I will give you is to shelf the air press idea and use some of that $300 to buy a membership with SOFA.-Clint
To add my 2 cents, I'd agree wholeheartedly with the above advice. Now, I'm in the PNW and know nobody in SOFA, but have been a member of my local association (NWBA) for a number of years. Not only have I gained priceless knowledge and friends, but MANY tools (and tools to make tools) from other members I've met over the years. Tools that I not only wouldn't have had any idea on where to start looking for them, but even some tools I didn't even know I needed. Many have swap meets like the one I'm prepping for in 2 weeks where I'm hoping to find parts for my press or rolling mill.
And, if you're as lucky as I am, you'll find that you live within 5 miles of 4 fellow smiths with full shops (with an already functioning press) that will swap shop time for a hand (or a beer or two).
