- Dec 15, 2009
As the others have said , practice
I've thrown away steel to be measured in feet, or hundreds of pounds and I'm still no good yet.
My comments are about getting the most out of practice
Start with one knife design, in one steel, in one thickness
and do say, 10 or 20 all the same.
different steels grind harder or softer, different designs have more or less area and such.
That way you will see and feel how the differences in how you grind affect the outcome in the same way.
These other tips are about seeing what each pass did, where the steel came off.
You can eyeball very very slight differences - changes of a few thousands of an inch, but it helps to have a standard reference.
I used layout fluid Dykem and very lightly scratched a series of lines on the blade before profiling basically in a grid.
That way I could eyeball one side to the other to make them match.
Of course I did 3 heavy scratch lines on the edge, one in the centre, two others ..010 on either side of that
I watched that to help keep my centred.
I started with a very fine 400 or 600 belt because my grinder was full speed and that was one way I could slow it down.
It also meant that if I decided it was time to stop grinding I was already at the end grit and didn't have to leave more thickness to run through the rest of the grits.
Turns out Ed Caffrey mentioned doing the same thing at one time so I felt all validated
When it comes to throwing out a blade, It's not all or nothing.
Do what you can to fix it like you are by thinning, or trimming the point whatever it takes.
That will help you think about how it went wrong and how to fix or avoid it.
Maybe you start with 10 Bowies and end up with 10 paring knives, if you don't tell anyone they won't know anything except what they have in their hands.
"There are no mistakes only design changes"
Hehe, that is sound advice Count. I agree about doing all the same knives, I intended to but I had those two bigger ones I profiled last year for my boss (was doing two because I figured one might turn out nicely and I'd keep the other). I even had different thicknesses because that's just what 5160 I happened to have on hand at that time. It sure made figuring out the angles to use with the jig a problem, because any changes I made were just one of many variables.
My next batch will be a lot more uniform!
When you say you started with a 400 grit, you mean you actually ground the bevels starting at 400? I'd never considered that..
My first knife I ground I did a center line, and two lines to either side as well, because I'd seen SR Johnson do it, and I like that method as well. This time I just did a center line and tried to eyeball the thickness. I will go back to 3 lines I think though, until I have more practice. I need to figure out what's wrong with my height gauge though, it doesn't seem to gauge accurately. I measured the height it was at with my calipers, and the gauge is totally wrong. I got it from Grizzly, but pretty sure it was made in a foreign country.. the instructions certainly weren't written by someone who speaks English as a first language anyway.
I haven't tried drawing lines for my grinds yet, as I frankly couldn't keep them from going over the top anyway. But after talking to you guys and Darrin I think I have a fighting chance this next time around. I will certainly try it next time.
Ya I am making these for my kitchen anyway, except the big ones I'll give away, so I'm not too concerned if they're perfect from a purely practical standpoint, they will cut food up just fine despite the flaws. But I am trying for perfection of course, simply to improve, which is a lifelong thing.
I definitely appreciate the advice, and making the most of my practice is exactly what I need to do.
