- Jun 22, 2006
No, Oxygen is not flammable in isolation. But, it is the world's best accelerant and in a pure form (99.5% is standard for oxygen cylinders) will spontaneously ignite in combination with hydrocarbons such as oil, grease, certain paints, adhesives, and solvents. Make absolutely sure that the cylinder you're using contained oxygen and not acetylene, propane, or mapp gas. Fuel gas cylinders can contain acetone (used to suspend acetylene) and liquid/dry fuel gas residue that is poisonous and/or volatile. If the cylinder is verifiably used for oxygen, crack the valves (outdoors) to reduce the pressure to atmosphere and you should have no problem cutting or grinding the cylinder. Good luck, and post some pics.
Whoops, you posted while I was in the middle of writing. Pics look great!
