- Jun 17, 2001
Went and took a look at TruGrit and saw this new belt: http://www.trugrit.com/belts-blaze.htm Anyone tried it yet?
Mark Williams said:I'm beginning to question the real cost savings on using cheap belts that dont even last one blade. Might be worth the added expense in the long run.
bladsmth said:Dan.Larger grit is more expensive to make than smaller( you can crush larger down,you can't make smaller bigger).This type of grit has no advantage above around 100 grit.It is the exposed sharp corners that do the cutting.In finer grits there is just not enough corner to matter.
HEHEHEHE!! Hey!!!! Listen I change them every year whether they need it or not.Fred.Rowe said:I Bring on that super belt, that you change once a year. Like George does his underwear. Fred
Fred.Rowe said:Bring on that super belt, that you change once a year. Like George does his underwear. Fred
