- Jan 12, 2005
It sounds like the name "Fluid" is appropriate then. I like that. My Bantams have a little resistance, so this sounds like an improvement.
With the blade closed, if you press the back lock bar while holding the knife parallel to the ground, will the blade drop "open"? I'm curious if the blade could be opened by depressing the lock and using momentum.
No. Of the 180 degree arc movement 1st 1/3 not free, next 1/3 very free, last 1/3 not free. Pivot is not like the bearing movement of the 830.
BTW, watch pocket carry is perfection with the fluid. The pocket clip holds well but also allows for swift and sure one movement pull removal from watch or main RF jean's pocket. Grippy FRN handle surface does not hamper the pull but actually gives thumb & index finger of R hand excellent grip! 👍
