New Hollow Handle "Survival" Knife- What do you think?
Sam Wilson
Hello, my name is Sam Wilson. I have been on the forum for awhile, and I recently decided to get into knifemaking. I have always loved hollow handle knives, so naturally, when I wanted a custom one, I decided to make it myself. I have posted pics of my completed knife, the Model 1, and as you can see, there’s a lot going on there. I have dubbed it the M.O.A. SYSTEM, for Make it Out Alive. I will try to explain most of it, along with the pics, but I’m sure I will miss some things. If you have any questions, please feel free to ask, and I will do my best to answer them. And yes, I am thinking about making these for sale as a knifemaker, so in addition to your feedback, I welcome constructive criticism. If there is enough interest, I will purchase a Knifemaker’s membership, and proceed accordingly. (Also, sorry, but I’m not much of a photographer. I will try to get better pics in the future.)
I would also like to take a brief moment to let everybody know that I was inspired heavily by several knifemaker’s work. I wanted to give them credit for their work before me, and the influence it had on me, and my work (which is obvious in the pictures), whether I ever sell a knife or not. The classic style of Bo Randall, the absolutely aggressive beauty of Jack Crain’s work, and the clean lines and grinding of Vaughn Neeley. And a very special thank you to Chris Reeve, and the innovation, consistency, and hard-working reliability of not only his hollow handled knives, but the Sebenza, which was my first high end knife, and all the other contributions he has made to the knife industry. Thank you all.
What I want to communicate to everyone is that I didn’t just throw this knife together. As you read through all of this, I hope that it is evident that I put a great deal of thought into every detail. I wanted to make, not just a hollow handled knife, but a real tool that provided the necessities for use in the wilderness, or survival, or whatever. First, this is a big knife. So I’m just going to start at the blade, and go from there. The blade is approximately 9 ½” long, 1 7/8” wide, and the handle, from the back of the guard to the end of the butt cap, is 5 ¼”. Overall length is about 15”. The steel is 5160 heat treated @ 58 Rc, and as you can see, I gave it an aggressive stonewash. I made it from ¼” stock, but I distally tapered it from about an inch in front of the guard forward, so the majority of the blade is closer to a little over 3/16” thick.
I know ¼” is extremely popular, but I really like my knives to cut and slice, and I believe that is still more than thick enough for just about anything you need to do with a knife. That’s also why I used a full flat grind, as it’s my favorite for these types of knives. I believe it gives the best combination of strength, and cutting ability.
Moving down the blade, I used a stainless guard, which I silver soldered in place. I know some don’t care for silver solder, but it was more than strong enough in my tests, and I believe it gives a touch of class to the knife. As far as the joining of the handle and the blade, there are three methods I used in conjunction with each other, and I personally believe that any two of those methods together are more than strong enough, but the third is there for insurance and peace of mind. First, the handle is channeled on the inside to receive the tang of the blade. The handle has to literally be driven on, it is such a tight press fit. Then, a ¼” steel pin is driven through the handle, the hole in the tang, and out the other side of the handle. It is then peened in place, on both sides. Finally, an epoxy which dries somewhat flexible, is poured in until the tang is covered.
In my testing, I could not get the handle off with a torch, hammer, and vise even before the pin was driven in, and the epoxy applied. So I believe that short of horrific abuse, the blade/handle joint presents no significant weakness. As you can see, I also radiused the corners to avoid stress risers, and increase durability.
As far as handle material, I live in the Pacific Northwest, and wanted to make sure I did all I could to prevent rusting. I used 316 SS, commonly referred to as Marine Grade stainless. The handle is cord wrapped, with approximately 20-30 feet of braided cord. One of the problems inherent in a round handle is the tendency for the handle to roll in the hand during heavy use. It doesn’t show up in the pictures, but I lightly contoured the handle on both sides where your fingers go. It is very faintly flat-sided there, to help avoid rolling and index the knife handle.
The butt cap is aluminum. I know that having a compass in the butt cap is very popular, but I decided not to put it there for a couple of reasons. One, if you use the butt of the knife as a hammer, it may damage the compass. Two, you would then have to unscrew the cap every time you wanted to use the compass. And three, I put something else there.
I have always had a hard time using the small ferro rods that fit into hollow handle knives. By the time you hold onto them, there’s not much area left to strike. And if it’s wet, you have next to no grip. So here is my solution.
Now you have something to get a good grip on, and can strike the full length of the rod. While we’re here, I will go ahead and briefly discuss the contents of the “survival kit.” I have only put the compass and the ferro rod in there. Everybody has different preferences and needs, so you can put what you want in there. The items are rolled up in the cloth, which is impregnated with wax. Now, in addition to keeping everything together, if you need emergency tinder, simply cut off a strip of the cloth, and you have an easily ignitable tinder source.
Moving on to the sheath, I like a clean front on my sheaths. I have found that the stone pouches on the front of other sheaths have a tendency to catch on things, and I just personally prefer to have the face of the sheath clean. So, how are you going to sharpen your knife? Here you go.
Also, as you can see, there is a PSK knife in there as well. It is stonewashed 1095, but I will probably use 154CM in the future, just for ease of maintenance. I will also probably cut a little vertical slit in the back of the sheath to slip the cords into, so they’re out of the way.
As you can see, there is not a strap that goes across the guard of the knife. As mentioned earlier, I didn’t want to clutter up the front of the sheath, and I have always disliked those straps. They have a tendency to get cut, and you have to pull them out of the way to resheath the knife. With the method I have used here, the shock cord stays pulled back and out of the way, the S-biner gives very positive retention, and resheathing is simple.
Additionally, once you’ve unbuckled the knife for the first time of the day, to avoid having to use the retention strap every time, I embedded rare earth magnets into the sheath. These serve the dual purpose of keeping the primary knife in place, so that the retention strap is typically unnecessary, and I placed them so that they hold the PSK knife and sharpening stone in place too.
I know this has been a very long post, but I am obviously excited about my creation, and wanted to make sure all the details were clear. I’m sure I missed some things, so if you have any questions, please feel free to ask away. I would also like to hear suggestions on what to do better, and what you like and don't like. Thank you,
Sam Wilson :thumbup:
Wow, some very clever ideas in here.
I really like the ferro rod handle solution and the magnetic retention.
Looks really good. A lot of nice details and innovation in that knife.
Thanks, Daizee. I've always thought the magnetic retention idea was cool, ever since my Dad had an RJ Martin custom that utilized them to hold the knife in a wooden scabbard. I appreciate the comment.
Thanks JTC. I put a lot of time into it. I can't wait to get out to the woods and tear it up.
I like the design and innovation. You should absolutely be proud to have made something like that, by all means. Congrats on cool idea and bringing it to life.
Very nice and well thought out.
The tang is just too short in my opinion.
That's a knife I would have put to good use in Iraq and Afghanistan. I wonder what you would charge if I were to want on for the next time I go back?
You've made an outstanding package there. I do have a couple of thoughts though. While you say you feel confident on your tang/handle junction, that will be the first place of concern for any prospective customer. I'd keep the same constgruction, but make enough allowances to include one more, offset, pin. The two will reinforce each other, and add a lot more strenght.
The only other comment is my personal tast. A blade with a nice, deeper clip would just be more appealing in my opinion, and finally, I'd reduce the blade to 8 to 8.25". That's plenty big enough for almost any survival situation.
I'd like congratulate you on a well designed and executed knife. You may want to post this in the customs forum, they love giving knifemakers input.
Beautiful work! I really love the clean sheath with the hidden pockets for a sharpener and PSK. Very neat idea.
Thanks, RevDevil. I am pretty pumped that it came together the way it did. I appreciate your help earlier.
Thank you Bill. You've given a lot of good advice in threads I've read about knifemaking on here. The tang is approx. 1 1/16" long. If I make it any longer, there won't be much useable space in the hollow handle, and I wanted this package to be very functional. How long would you suggest making it? I thank you for your input.
JMSelf, I don't have a knifemaker membership yet, so I can't sell on here as of now. I had a great time making this, though, and part of the reason for making this thread is to see if there would be enough interest in my knives to warrant buying a knifemaker membership. I hope to see over the next couple of days/weeks, and if so, I will contact you. Thank you for the interest, and hopefully I will be making you a knife soon.
Thank you, David. This and Bill's comment are exactly what I'm looking for. Concerning the second pin, I don't know enough to know what exactly that would do to increase the strength of the knife. I can't see somebody breaking the 1/4" pin that's through the handle already, and the blade is slotted into the inside of the handle, meaning, when you look at the knife without the cordwrap, the blade tang is totally inside the handle, in a channel. The blade tang is not visible from the outside at all, so somebody would have to break the 1/4" pin, and then breach the 1/8" thick steel handle tube, to destroy it. But I would love to make improvements, and I genuinely would like to hear what you mean.
I agree with you about the size and shape, it's not for everybody, and it is a matter of personal taste. I just love huge knives, and this shape is very utilitarian, provides for a very strong tip, and looks aggressive. I will eventually offer smaller versions of this, and my Model 2, which will look something like this:
That one still needs to be finish ground, but you get the idea. I hope to eventually have 9 1/2" and either 7 1/2" or 8" versions. The nice thing is that the sheath is easily scaleable, since all the goodies are in the top half. And I may just start a thread in the customs forum, with some pics, or a link to this thread. Or maybe one of the moderators would move this there for me. I will look into it. Thank you for taking the time to help me out. I don't know if it will work or not, but as soon as I started making this knife, I knew this is what I wanted to do. The bug bit me hard. :thumbup:
Thanks, man. I love when the front of the sheath is clean, and I hate those straps that cross over the guard. Especially on these large knives, it almost takes two hands to put it back in the sheath, one to hold the strap, and the other to sheath the knife. Thanks again.
I would hard solder the guard to the handle, lengthen the tang (even a little bit,) and use your silver-bearing solder to attach the blade to the handle/guard, then use your epoxy.
This way, the guard becomes an integral part of the handle-adding strength.
I think you have a well thought out presentation there.
Thank you very much. I have to say that I am a little proud of it. I appreciate it.
Thank you for replying, Bill. I will have to try that on some scrap, and if I get the skill down, I may incorporate it into the knife. That would probably be stronger than what I did. On the back of the guard, on the inside of the handle, I drilled 6 1/8" holes, about 1/8" deep into the guard, to form little craters, making epoxy "rivets" into the back of the guard. Additionally, I put epoxy between the handle and the back of the guard, serving a similar purpose as the hard solder you referred to. But I didn't think to do all that with hard solder. This is why I wanted to post this here, to get perspectives from real knifemakers. Thank you for taking the time.
I like it! I am an knife user, not a maker......
I would prefer more belly - more graceful of a sweep in the edge up to the point.
You could keep the swedged spear point, but give it more belly for skinning and cutting long shallow pull cuts.
Very nice.
Let me know when you join up here as a maker and start selling these!
best
mqqn
Very nice.
best
mqqn
Thanks, mqqn. I'm glad you like the design, and I appreciate the compliment. And I am more than happy to get input from users, not just makers, ha ha. That was one of the hard things when designing this, as was mentioned earlier, there's a lot of variation in personal taste. I basically designed and made the knife I really wanted, and hope other people like it, too. If this gets enough interest, I will eventually do custom orders to a certain degree, so we'll see how that goes. And yes, I will let you know when I join up as a knifemaker, and get the ball rolling. I'm really looking forward to it. Thanks for commenting.
Sam
Sam,
As others have noted, Very well thought out concepts and execution. Continue to work and test all different aspects of your design to look for possible improvements.
I also think the inner sheath compartments are a great use of space and very clever. One thing I suggest regarding a retention strap is that I had a sheath maker that I told to put a pivot on the back of the keeper strap instead of sewing it down so you can rotate it down the back of the sheath while working with the knife and when you are really to go. Rotate it back over the top rear corner of the sheath and button it down. I am on a Ipad now or I would post a picture for you.
Keep them coming. You are doing great!
