Sando
Knife Maker
- Jul 4, 2002
BTW you can't really compare the wear resistance or cutting ability of 2 different steels, based on hardness alone.
Take for example 2 knives at 58HRC. Some might say they will both have about the same wear resistance or edge retention. However, if one blade is 440c and the other is S90V, the S90V is several times more wear resistant. (http://www.crucibleservice.com/datash/dsS90v7b.pdf)
Why? you have to take into account all sorts of factors, including the type of carbides and grain size and such. For example, ZDP-189 doesn't have any vanadium. And vanadium carbides are much harder and finer than chromium carbides. So for ZDP-189 to compare favorable with a high vanadium steel such as S30V it probably has to be that hard. Which makes it brittle, which requires a laminate, .....
So while it's fun to compare HRC numbers, unless you're keeping the type of steel the same it doesn't mean much.
Stev
Stev
