Hey Jason, thanks for the heads up! It was a pleasure to work on, nice to see a different knife in front of me once in a whileI'm glad you're happy with it, it's great to see a basically unusable knife get a new life :thumbup:
Scrteened Porch, they're not putty knife blades, just thin shim stock, the liners were slightly bent in so I slid the shims in to hold them out a bit while I hammered the bolster pin. It's makes it a bit easier to get the blades to walk and talk afterward, with a lot less chance of popping the pin in the process. The gap that they produce is eliminated when they're removed by the pressure of the newly hammered pin. This would normally be too much on a new knife but it works perfectly in situations such as this.
Eric
Holy crap, that looks great!
That wasn't a former Camillus employee that did the work, was it?
Thanks for the tip. That would have improved my last effort, and will future ones.Scrteened Porch, they're not putty knife blades, just thin shim stock, the liners were slightly bent in so I slid the shims in to hold them out a bit while I hammered the bolster pin. It's makes it a bit easier to get the blades to walk and talk afterward, with a lot less chance of popping the pin in the process. The gap that they produce is eliminated when they're removed by the pressure of the newly hammered pin. This would normally be too much on a new knife but it works perfectly in situations such as this.
Eric
These knives are generally manufactures from 440C stainless steel and "clean up" quite nicely. The man did a good job on the TL-29. Remember, these were/are built to military specifications (mil-spec). What people ignore is the fact that they are built to withstand a beating. These knives are often used on board ship (I used them during my hitch in the Navy, right alongside Marines that were performing the same maintenance on aircraft). They're also used on Air Force, Army and Coast Guard ships and bases as well.
They're still being produced as they have for more than 70 years. In the early days, they blades were made from 1095 steel. Today, they all use 440C steel hardened to 58-60 HRc. Military specifications are quite precise in these respects. Nothing less is acceptable. The ability of the GI to use these knives as a screwdriver/wirestripper/drop-point blade knife is absolutely essential. This is why they hold such an important place in the hearts of service members.
Yes Frank, The TL-29 was traditionally made with blades made from 1095 carbon steel. Today, Colonial makes them from 440C. If others make them from 440A, I'm not certain of how they would be "mil-spec".
