Make sure your steel platen is FLAT if not you'll crack that puppy in no time.and next time,use plate glass.dirt cheap and works just aswell.
Here's a pic of the ceramic platen. It has no screw holes and the Ellis web site's directions call for JB weld. Should I try and make screw holes with a step drill bit or just jb weld?. I am going to put a lip at the bottom of the steel platen in the event it were come unglued.
Ok here's what I have so far.
1. Took off the platen, gave it a few passes with 30 grit belt.
2. Drilled some metaltapping screws through the rear of the plate to provide a lip of sorts.
3. Here is the pic of the ceramic platen as it will be once I jb weld the baby on.
I also washed the two platens very well. And will glue and use tape or tie wraps to hold for 24-36 hrs to let it set. I will post the finished pic when its done. Thanks for all the advice.
Patricknives,
I know I know, but I just couldn't control myself or wait.I just ran out like a little kid and bought the cheapest one with decent reviews. I will get me a good one someday.
