- Jan 12, 2015
The danger is with what are termed "Drying Oils" ... Linseed, Tung, Walnut, Safflower.
These oils react with oxygen to form polymer chains (polymerize) and harden over time.
Non-Drying Oils such as mineral oil, vegitable oil, canola oil etc. do not react and will stay oily and do not undergo the heat producing reaction.
As the Drying Oil react with oxygen, that oxidation reaction produces heat. When the heat is concentrated ... wadded up or covered with other material the heat can buid to levels that will ignite the oil. At this point you basically have a giant candle, with the rag as the wick.
The rag should be laid out flat, hung over a fence etc. where the heat can not build up. As an alternative the rag can be sealed in an air tight container (no a normal trashcan is not air tight) or left submerged under water. Anything that prevents oxygen from getting to the oil will stop the reaction and thus no heat. However, no reaction means the oil will not dry and when air is reintroduced the reaction will resume.
The danger is much more significant with "Boiled" oils and varnish-oil combinations where other ingrediants have been added to speed up the process. Same quantity of heat is generated but boiled will all happen in a day versus spread out over a week with raw.
