Different machines using different media and at different times.
To be valid they have to be tested at the same time in the same session using the same machine and media, so the data can't be compared directly from the 2 sessions.
The numbers don't line up from the 2 sessions so the media and the HRC ranges had to be different, and on different machines.
Yes, but even if those two sessions cannot be compared directly, they still can be used for some way of organizing data.
For example one can say that S30V performed 13% better than 154CM (both at 60-61HRC).
Also Elmax(62HRC) gets 22% edge retention increase over Elmax(60HRC) in this test. Elmax(62HRC) is merely 3% worse than M390(61HRC).
One M390(61HRC) blade can cut almost as many cards as two 440C(59HRC) blades.
and so on...
One thing I can get from this is that in usual daily tasks I probably will not feel much difference between S30V and 154CM (at the same hardness), maybe will feel a slight difference between Elmax @60 and @62. Probably will use M390 blade twice longer before sharpening compared to 440C blade. I can see how steels can be rated based on the performance in these tests, but in reality I can see that in some cases the difference is not all that big.
