- Sep 19, 2001
Wilson/Goddard are pretty much why I said anything more precise than a pound isn't repeated, because they measure force on rope cutting in pounds. I don't think there is a machine that replicates CATRA, so even if we had results from different users, they're all just pushing buttons on the same machine. We could find variation from changes in blade design, but not see what any inherent faults with the machine are. There isn't a medium close to and consistent as the impregnated cardstock it uses, so it's tough to say a freehand cut on rope correlates to a machine precise cut on silica bearing cardstock, particularly if we don't know if the steel matches up between tests.
I don't think anyone has to perform tests to be able to comment, but I think there should at least be productive comments. Every now and then there's a comment to the effect "I disagree with your results, despite having generated none of my own and working off hearsay in a field I do not study professionally, so your tests suck." If actual problems, other than not having a favored steel come out on top, can be pointed out things would improve. These problems also need to be acknowledged and addressed.
I think to determine if different edge and primary grind angles affect edge life in rope cutting, then blades of the same steel & HT with different angles need to be tested in the same way against the same rope. I think that if freehand cutting side loads the edge, either you have to fix the blade in a jig, or accept that knives are hand tools and the effect of human imprecision must be accepted and accounted for and testing needs to be extended. Ideally, do both with the same blade and see what the difference in the results is. I think more work needs to be done to see what quantified difference edge finish has, and how different steels are affected by it. I think the condition of sharpening equipment needs to be monitored and held constant so your stones aren't glazing, getting rougher from lapping, or your diamonds aren't fracturing and changing your edge finish while you expect it to be the same. I think all tests should have micrographs of the edge, and the included angle should be checked with a goniometer as well. I think material cut should be consistent, I think the force measuring devices need to be calibrated, and I think types of cuts made should be well defined and accurately repeated.
I also think this is far too much to ask of any of us hobbyists, and even most professionals who make money selling knives, not testing them. Really, in the end, we as a whole barely test the limits of the designs and don't have to sharpen or cut enough to make it economically feasible for anyone without a grant and research facility to look at all this for an industry were 420J2 outsells most other steels by sinful margins.
