DaQo'tah Forge
Banned
- Aug 26, 2002
No, my advice for a new kid is to stay away for jigs and rods and the many triangle sharpeners on the market,,,,,they are just the wrong way to learn...
They are easy, they are fast,,,but they don't advance the persons understanding of what sharp is.....
However there are 2 times when even I switch and use my tri-stones,,,,,
1-when in the middle of something, like cutting up a deer, a tryangle sharpener will help be do a fast fix on a blade that might have a flopped over edge.
2-an oil stone is worthless when dealing with a serrated blade, you got to have a triangle sharpener handy for such knives.
BUT the Huge draw-back of all triangle stones is that they can not raise a burr,,,,and without raising a burr you are just not getting the knife as sharp or as even as you could,,,,
The design flaw of the triangle sharpener is that as you draw down on the blade against the stone the rods are just following the edge of the blade. Yes, the rods just follow every up and down in the blade, every dip, every ding,,,every flaw in the blade is only made worse.
When you also use a tri-rod sharpener you have a tendency to just "count" strokes....you also have a tendency to flip from one side to the other, back and forth....But this is the wrong way to go!...
Here is the deal with sharpening any blade....
When you sharpen a knife, you have to just sharpen one side fully first. You MUST have a burr all along the first edge before you flip the blade over and start sharpening the other side.
If you do not raise a burr?....Then you are not done!,,,
Any sharpener that can not raise a burr along the edge of the knife you are trying to sharpen is never getting your knife as sharp as it could be...The number of strokes per side is besides the point, counting them is pointless. In fact counting strokes on a sharpener leads to thinking the knife is sharp based only on a number you counted to ......what difference could that possibly make?
