You neglect to mention the multiple times he altered the grinds of "test" blades, and then reported the findings as fact.
You can use all the technical language you want, but when your base assumptions are wrong, it's nothing but hot air.
Alterations which you and I only knew about because he told us about them in the first place in text and pictures, so I'm still---after all these years---at a loss to understand where the controversy comes from. His primary interest was in alloy comparisons, not in whose name was on a blade, and as he wanted to draw comparisons, he would set edge angles to be equivalent (or at least MORE equivalent) and then run them against each other through various cutting media. Makes a whole lot more sense than running one alloy against another with different geometries and then trying to extract some sort of meaningful data. It's because of that type of lack of understanding that alloys like ATS-34 and S30V gain reputations for being "hard use" because a manufacturer makes saber-ground, 1/4" thick fixed blades out of them with edge geometries like cold chisels. Hell, at that geometry, aluminum is pretty tough.
Don't get me wrong, he could be abrasive at times, I had a few run-ins with him myself over the years and by the time he was banned it didn't come as much of a surprise to me, but as an engineer it was remarkably refreshing to see an ATTEMPT at qualitative analysis versus the typical "tests" that often appear on knife sites (and I won't even bother going into the drivel printed in knife magazines) which leave so much information unaccounted for as to be absolutely meaningless:
"I cut up this cardboard box, and then sliced these carrots (insert picture of knife next to a partially disassembled carrot) and then ate my steak with it, and when I was done the blade didn't explode and it was still kinda sharp. Here's a cool shot of it sticking out of a stump next to a compass. Hence, I think it's a good knife with awesome steel."
................thanks dude.
Alter the grind and it ceases to be the knife you started with. If he wished to study grinds or steels, get them ground to spec- don't change what's out there then declare one a winner based on those "tests".
Sword that makes no sense!?! That would again testing the knife, not the alloy. Edge geometry has to be same on different knives of same alloy to have a control for which to draw credible conclusion about the performance of that particular alloy. Not just what that one company did with that one knife.Alter the grind and it ceases to be the knife you started with. If he wished to study grinds or steels, get them ground to spec- don't change what's out there then declare one a winner based on those "tests".
I have some issues with Cliff also, but he was a definite breath of fresh air. He did a lot of pioneering work, and there are a couple of knifemakers on this forum that can probably thank a large part of their popularity to him, and I'm not necessarily talking Busse.Alterations which you and I only knew about because he told us about them in the first place in text and pictures, so I'm still---after all these years---at a loss to understand where the controversy comes from. His primary interest was in alloy comparisons, not in whose name was on a blade, and as he wanted to draw comparisons, he would set edge angles to be equivalent (or at least MORE equivalent) and then run them against each other through various cutting media. Makes a whole lot more sense than running one alloy against another with different geometries and then trying to extract some sort of meaningful data. It's because of that type of lack of understanding that alloys like ATS-34 and S30V gain reputations for being "hard use" because a manufacturer makes saber-ground, 1/4" thick fixed blades out of them with edge geometries like cold chisels. Hell, at that geometry, aluminum is pretty tough.
