Ah, you're right! I was too focused on the pretty two-tone.A few posts back has a picture with Casey's clip
Sent from my XT1049 using Tapatalk
Has anyone with a Nirvana that has a lock-stick problem contacted Spyderco and got their take on the problem ?
Has anyone here formally contacted Spyderco? Does anyone disagree that they should know about these stiff and sticky lockbars?
With essentially everyone reporting the lock stick issue I feel like Sal should know. This is possibly their most anticipated models in years and we have to break it in and put Sharpie or graphite on the lock surface? I'm happy with mine but after paying well over $400, it certainly takes a bit of the sweetness away from what is otherwise a phenomenal knife. My Techno never had a lock issue or a break in period and I paid less than half the price of the Nirvana for that.
I have been trying to break mine in for over 4 days now and the stick is still just as extreme as it was before. I wiped all for eh excess oil off and haven't seen a speck of it on the lockbar, and I added graphite which did nothing to resolve the issue, so I am now returning the knife.
My fingers started to actually bleed and split two days ago when I made the decision to return it. I know that some knives do take a while to break in, but this is ridiculous to an extreme degree. It seems like mine is the exception and not the rule, but still this is absurd...
So you use a knife so much that your fingers bleed, but then you are going to return it? It's a used knife, you should not return the knife, it's yours now. Send it to Spyderco, if it really has a problem they will fix it.
Did you try to set the lockbar?
The amount of Lock stick is the only sticking point(pun intended), to an otherwise superb knife. I tried cleaning, graphite, sharpie, opening and closing, etc. It's a little better, but still problematic. I tried removing the pivot to remove the blade for thorough cleaning. One pivot loosened easily. The other would not. Instead of being smart, and stopping, I kept trying, which partially stripped the pivot head. I called Spyderco, and the Rep is sending me a replacement. Now I have to figure out how to remove the damaged pivot. Any constructive thoughts would be appreciated.
Other then the lock stick, the knife performs as if it were a custom. Here's a post processed image of my baby.
