- Jan 15, 2008
Beautiful & unique Bruce. Can you tell us a bit about the guard mechanism?
Sure, the guards are identical but one mounts on the left and the other on the right. I spent a week making them operate. I used a switch blade coil spring from knifekits.com in a special milled pocket under each one. The 1/4" shaft pin is turned on the lathe and peened over a special washer, all 416 stainless. There is a center pin brass bushing and .005" thick flat brass washers under each guard.Beautiful & unique Bruce. Can you tell us a bit about the guard mechanism?
Couldn't agree with the bolded text more, Mark.I don't know how to say how much I like this knife, previous posts do an excellent job.
I don't know how you're going to top this but then again you've probably got a head full of unrealized ideas.
You know you're not normal?![]()
Mmmm, thats a good idea. I bet the switch blade spring will fire a round with a short hammer. Sometimes there are space problems on leaf springs for a gun but a coil spring would solve that problem and be reliable and serviceable.Couldn't agree with the bolded text more, Mark.
When I first clicked on the thread I thought the above quoted image was a cocking mechanism to chamber a round.
Doug
