bigmark408
- Nov 13, 2006
all i can say is it may have been a shot at perfecting perfection, but Chris nailed it with the 25 (IMO).
Just cleaned mine tonight. Can't say it trapped grit and grime, but all of my grease was missing lol.
Yeah. The question is if it's just marketing schtick or if it actually does that, and does it make a difference?
I guess the question is whether the out-of-the-box smoothness is due to finer tuning at the factory or merely changing to perforated washers.I've been collecting, using, and abusing the Sebenza for about 18 years. Within the last year and a half I've noticed a big difference in deployment smoothness. Not saying the perf washers are the reason, just saying. There use to be a "break in period" for smoothness. Now most if not all come this way out of the box.
You may be right. I just don't see anything "gunky" getting in between the blade and washer when the pivot is tightened down to an adequate tightness. There is just no room for anything other than liquid. I thought the perforated washers were meant to hold grease, not give room for any particulate matter room to escape.
Old hardware:
solid washer + blade tang + solid washer = 0.1530"
old pivot bushing width = 0.1535"
old pivot bushing diameter = 0.3165"
Stock hardware:
perforated washer + blade tang + perforated washer = 0.1535"
stock pivot bushing width = 0.1535"
stock pivot bushing diameter = 0.3160"
So. The solid washers stack-up with the blade half a mil under either pivot bushing, allowing the free swing that I described. The stock perforated washers stack-up exactly with the pivot bushings, allowing very smooth operation, but not free swinging. However, the old pivot bushing has a slightly larger diameter which binds the blade enough so that with either set of washers it feels tight.
I'm not so sure about this... 0.0005" is very small. My calipers' smallest increment is 0.0005" not 0.0001", so the variation might be slightly less or more and my device is rounding. Having such a small variation on a 3 component stack-up is very impressive, and I'm guessing the variation is well within whatever tolerance stack-up CRK uses.It appears CRK made the perforated washers slightly thicker, perhaps to maintain the same stiffness with the holes.
The Stock hardware is the washer/bushing set that came with my large 21 from the factory. The Old hardware is the old solid-washer/bushing set that MVG sent me. The blade is obviously the blade that came with the knife from the factory.
