Bob & Eye Dog, thanks for explaining the considerations that must be taken into account to get the EO notch 'just right'.
I don't think we old geezers are the problem, with or without arthritis. It is a GEC issue. No slipjoint needs a spring that makes the pull anything over about a "6". Spring tension is needed so that blade will not fall open on it's own, and so that it will not get knocked off the fully open position too easily. The spring tension on many of the GEC knives far exceeds what is needed and this is an "issue" far more serious than a liner/spring gap, or an off center blade, etc.
I have a Forest Jack in mammoth that is a 9 or even 10 as it does break nails. I work outside a fair bit so my fingers are fairly strong and my nails are thick. I intended to carry and use this beautiful Forest Jack, but whenever i pick it up to pocket for the day, i think "i don't want to deal with the struggle every time i want to cut something" and i put it down and use a different knife. I bet many others do the same. That is, this $300, Top of the Line knife is difficult to use.
The proper fix for this knife is to replace the spring with a thinner one, but that means taking it apart and wrecking the mammoth handle slabs.
If i was Derrick and laid out a lot of money and then received these defective knives, i would be hopping mad and at a minimum would let GEC know this is entirely unacceptable.
Springs as stiff as many GEC's are is a defect. To call it anything less is denial, not wanting to admit to yourself that your expensive knife 'ain't right'.
Now, before you all jump on me, i am meaning this only for those knives at the extreme end of 'too stiff', but this is actually a lot of GEC knives.
kj
