- Dec 10, 2006
I'm also curious why a framelock is going to automatically get wedged in the open position? I have had a couple fail and they do so by the lock walking to the unlocked position and closing. I don't see a reason why a framelock only will 'fail' to the locked open position?
It wont only fail to the locked position. What you experienced might be poor lockup design where a few things can factor in. The engagement surface of the lock, the lock face (of the blade) angle (I dont have the book with me but Bob Terzula explains in detail in his book) I believe anything less then 8* will make a lock slip and anything above 10* will make it jam or slip (I am under correction until I can reference it) but poor lock design and execution will result a framlock to slip of the engagement area as you described. (though Bob Terzula discuss liner locks makers apply the same principals to Framelocks). These are some factors, but there are many others, if possible get BT's book and have a read. It is a great book to understand liner and framelocks better.
The advantage of a Framelock is that if you grip a well designed and executed framelock the lockup will increase and the force of your hand behind the locking frame itself can prevent accidental slippage off the engagement surface as you described. A well designed framelock also tends to 'bounch back' to its original lockup engagement if the lockup is increased through hand pressure. Or that has been my experience with ZT, CRK. (I own a CRK and only plaid with a ZT, but both well designed framelocks IMO)
