Blade Grind
Ed, I wish I knew every step taken. But, it was about 2000 and Buck changed lots of grinds to the EDGE 2000 program. ( The blade date code will start about the ] symbol). That program was promoted by them as the modern future and improved there ability to make a high quality edge grind. This also included new 'fine blanking" process where there is a male and female blade die and the stamping goes all the way thru leaving 90degree edges. This may have reduced some manufactoring steps from the old method ?. There was lots of angle talk at the time. And this new grind was done to reduce the angle of the final grind. Some folks still like the flat grind from the old method as they think it supports a stronger edge. Some are OK with what we got now and Buck says it will keep the edge sharper longer. I have not chosen a side in this war. BCCI members can go the the website and look in the 2000 Buck catalog where this change and process is discussed.
I keep showing those knives and hoping someone might take notice. I need to get one fixed with a regular clip and a custom SF or Warcliff that is full length to the blade well. If I do I will do one opposite end and one same end to promote discussion. No matter which you have you still have to pin each end to hold the thing together........
I will be taking these knvies and traveling to the factory at the end of July 2013, as will lots of other Buck nuts, as we have our 50th year club celebration with factory tours and seminars right there at the factory Idaho. You BCCI folks start reading up on it, the Dec. newsletter is on the way.
300Bucks
