alright. This went from a WIP to just wanting to get the darn thing done. took me FOREVER to do all the fabrication (guess my time is cheaper than a $8 project box...). Made a heat sink for the SSR. Rigged the circuit breaker for both legs of the heater element directly downstream of the buss bars so all juice has to flow through the breaker first before exiting the box. This keeps Timmy from getting cranked when he opens the door. Rigged the fan to come on when I flip the switch to turn on the controller, and stuffed all of it in a plywood box that a bum would be ashamed of. Down the road I am gonna rebuild the box nicer, but it works for now. I need to make a cover for the studs on the back of the kiln, and the back of the box so nobody gets a jolt. I did put 1A fuses on both legs to protect the controller and fan, after the switch.
So, I flipped the switch and nothing went pop, but the fan did not come on. I put the bridge rectifier before the the transformer so the transformer was getting 220 VDC for a sec or two. Moved the rectifier to after the TF and now have 12VDC. Switch on, fan works. Oh yea, and the controller turns on. I ran the TC wire all I have to do is hook up the high temp wires, connect the TC wires to the top of the kiln, and build the door. Then done. I think part of the reason why I gave up on the WIP is I still have not deciphered the directions yet for teh controller. I am gonna read that sucker 852 times if I have to till I understand how to use this thing.
