Cliff Stamp said:
This isn't a binding material.
You can also hollow grind dual ground blades if you want to reduce friction,
You can also get the same built in angle guide if you zero v-grind, this isn't something particular to chisel grinds.
-Cliff
I wouldn't know a material which binds more that meat or fish? And it doesn't have to be binding forces. Cabbage or squash binds very little and it is very difficult to get a straight cut through it with a chisel grind. Big surprise, after all the blade essentially bows to one side.
Of course you can double hollow grind to minimize binding, you can even double convex with a median ridge, which is the geometry of a katana for this exact reason. There are many ways to slice a cake. But only in the chisel grind you get the wedging on one side with reduced friction on the other. Again suitable only for certain particular purposes.
Sure you get the same sharpening benefits in a double v to zero edge except for the burr cut of, which is particularly easy, I find at least, because the blade "bows" in the direction of the burr formation, but I agree that you could achieve the same, by lifting the blade a little from the bevel when cutting off the burr on a double v. I would still think that holding the knife while sharpening would be much less arkward in the chisel grind since for a total 20 deg (actually, my usuba was more in the range of 15) included angle you are holding the knife at 20 deg, while you have to work much closer to the stone at a double bevel at 10 deg each side.
Hey, I don't want to defend the chisel grind. I like it in the kitchen and it has its uses and benefits, but in a utility or folding knife, I prefer full flat. And of course symmetry has the benefit of versatility. It can replace a chisel grind blade, even if it may not be as suited to the task, while the other way round is not the case.
Blade two: Yes I was aware of that, that's why I got a left handed friend of mine a Messermeister instead of a Masahiro. Thanks for the info though!
