As Don states, remove the blades from the kiln. When your cycling the steel in an electricj kiln it's getting it to temp thats needed. Leaving the steel in the kiln and letting it slowly cool will increase the grain size. I cool blades quickly when normalizing, once they loose their color it goes in the water. It won't warp once the colors out of it and the quick cooling gets the steel through the soft structures faster, which is a good practice. Blades are so thin they take little soak time when the come to temperature.[/B]
ok, that makes sense. thanks.
I would also like to add that the warping that I am having trouble with is not always noticeable by looking down the blade but apparent when placed on a flat surface and looking for light peeking through or pushing on the ends (point/pommel) and watching the opposite side lift. The more severe warping is obvious when looking down the blade (2/7 blades today)
I notice that a lot of the blades are warping where I stamp my logo. I bend all the blades dead straight and surface grind to make sure they are within .001" consistent in thickness after stamping yet still the problem persists.
does anyone see anyone see any problems in this HT regiment?
Stress relief:
place blades in cold kiln without anti-scale compound
1200F 2 hours, cool in still air
Hardening:
Place blades in coolf kiln, no anti-scale compound
RAMP to 1250, soak for 20 min
Ramp to 1490, Soak for 30 min
quench in 130f Peanut oil
remove from oil when 130f
sit flat on wood bench until at room temp (when all the blades are done being quenched)
go inside the house
Tempering:
400f 1 hour x3
unless I am fixing warps (and I am all day)
clamp to flat plate using a penny to use as a point to bend against the warp for 30 min of heating until room temp and then checking for straightness.
I'd really like to not have to guess when the right time is to pull the blade from oil to bend by hand. Honestly it seems there is too much room for error, but I am probably wrong. I am definitely frustrated and tired of spending entire days straightening blades. I tried heating to 400F and bending in vise but it didn't seem to actually do anything to straighten them
