I'm trying to follow this thread as best I can and get about 90%. I recently purchased an expensive double edged tactical blade in S30V. It is recurved and I am having a frustrating time getting the edge hair popping sharp. I am currently using a spyderco sharpmaker and even went to the trouble (and expense) of purchasing the diamond hones.
That sounds good..........but in reality it is only a theory
Or that it's not there and it should be.
I have had NO such experience with S30V whatsoever....however, I use a $2500 variable speed Hard Core Grinder and do not hand sharpen anything. I start sharpening dull S30V with dull 220 grit premium 3M ceramic belts, then polish with a dull 400 grit blue belt, then over to a medium felt wheel loaded with green chrome rouge.
I steel kitchen knives all the time, sooner or later they need a higher level of sharpening, but under my 20X loop they show no pitting.
Originally posted by brownshoe
Maybe your steeling phenomena is just a symptom of poor sharpening technique, poor heat treat or poor steel, and not small chipping due to blade realignment.
originally posted by brownshoe:
I steel kitchen knives all the time, sooner or later they need a higher level of sharpening, but under my 20X loop they show no pitting. Does this disprove your theory? Maybe not, since it's a different steel.
orignally posted by brownshoe:
In addition, when I read this thread, I don't see complete agreement with your scenario.
Originally posted by brownshoe:
One observation, one knife, low power magnification, does not prove a sharpening theory. Never will. Neither will a preponderance of anectdotal evidence.
Originally posted by Cliff Stamp
Yeah, there is a section called "Why does my knife go dull so fast?", this note needs to be added. This is usually the most important section of any guide as it is always the one that you go to first because everyone only reads the instructions when something is broken or doesn't work.
originally posted by Cliff Stamp:
<snip/>it doesn't get very hot here, unless you are a woolly mammoth in which case you might find it a bit hot - but its a dry heat.
For clarity, Mr. Brogan, the word pitting was used as a synonym for micro-chipping.
The theory is the reason you and cliff give for the phenomena.
<snip/>
The theory comes when you apply that phenomena as a reason for your problems with maintaining the factory edge sharpness and durability.
A simpler explanation is that with your hand tools you cannot obtain the same edge angle, with the same amount of precision accross the blade and the same level of polish.
Maybe this is why your factory edge lasts longer and cannot be ressurected by your hand. I donno, just a theory.
Why the big push to invalidate what Cliff wrote in this thread?
...they never mentioned dry air
For your theory to be valid, it should describe what has been happening.
Taking a wire and bending it back and forth to change the metal structure into a more crystalline form which breaks is a known phenomena. The theory comes when you apply that phenomena as a reason for your problems with maintaining the factory edge sharpness and durability.
My limited point from the beginning is that theories are not fact ...
There appears to be a direct corrollation between materials I like and there decline in use.
