- Apr 21, 2006
I am really disappointed. I suspected that CPM S30V is not better then CPM S60V, but did not expect such a difference in CATRA edge holding tests recently reported.
Vassili.
As I stated before S90 was the replacement for S60V. S30V wasn't, and is in what could be called a different category. In addition, you seem to have missed that they ran the S60V way higher for this test than they would/could have on a production knife blade due to it's often discussed and well known problems. A much more realistic hardness level for S60V would have been in the RC 56 to 58 range, where it had other problems caused by the low hardness numbers such as rolling due to lack of strength.
This was known long ago. I recall reading a TK magazine where the steel ( then called T440V) was introduced on the Millie. Already, back then it was known that S60V probably wasn't the answer, and that S90V ( then called 420V) was more appropriate due to the ability to run it harder without chipping , or rolling at the lower RC's needed to keep s60v intact. These unrealisticly high hardness numbers undoubtedly added to the CATRA numbers recorded here. I very much doubt that the average RC 56-57 S60V would have recorded the numbers shown above.
S30V did come out much later but, if some in the business are to be believed, as a stainless version of 3V. I have no idea if that's true or not.
S30V is generally acknowledged to be a good steel, but difficult and fairly expensive to make knives out of. As a stainless 3V it might be called a failure but that's subjective and not meant to be called a failure as a premium steel.
S90V and others in it's class ( ZDP, etc. )are generally referred to as super premium steels.
