Sandvik does not use PM. Their steels have sub-micron carbides due to the balance of alloying. 19C27 is a different animal that they created specifically to create larger carbides.
The carbides are the white areas in those images. The grains are larger than the carbides in the PM steel. Fine-grained steel still has grains 10 microns in diameter, grain size does not influence the radius of a sharpened edge.
All steels lose initial sharpness quickly. The abrasive wear and plastic deformation against the edge where the pressure is immense will cause a very rapid increase in the radius of the cutting edge. As the edge radius increases, the pressure and rate of wear decreases relative to the force applied.
You are posing a misunderstood question.
The best answer one could give to your question is: That's just how the steel performs. High vanadium steels don't rely on the starting sharpness for the majority of its edge retention.
On the one hand, I seem to have really stepped into something messy here. On the other hand, I'm still learning something new in all this.Sandvik does not use PM. Their steels have sub-micron carbides due to the balance of alloying. 19C27 is a different animal that they created specifically to create larger carbides.
