all added up
feel free to edit this... list..to add more it's adding up
Leather apron
Trend Airshield
Didymium glasses
gloves
fire extinguisher
ventilating system
First aid cabinet
post vise
table saw-wood
band saw-wood
drying cabinet
vacuum casting outfit
micro torch system
Sharpening stones,laps,hones,etc.
12" grinding wheels
Beer cooler
Rockwell hardness tester
CNC mill
CNC lathe
100# Little Giant
variable speed Bader lll
metal cutting bandsaw
drill press
Rotary table for the mill
collet indexer
2X72 variable speed, for hollow grinding
2X72 variable speed, for flat grinding
2X72 variable grinder with small wheel attachment
2X72 variable grinder with Rob Frink rotary platen
9" disc (variable/reversing)
12" disc
16" Disc Grinder
Surface grinder
Surface Conditioner
Drum Sander
BOSS oscillating spindle sander
Die Grinder
Dremel tool
400,000 rpm rotary tool
Right Angle Grinders
Metal cutting bandsaw
Wood cutting bandsaw with carbide tipped blade
Table saw
Chop saw
Beverly Shear
Welding /Cutting:
MIG welder
Plasma cutter
Oxy/Ace torch
Heavy Machining Tools
Mill
Mini Mill
Drill Presses
Metal lathe
Wood lathe
Granite surface plates
Height gage
Calipers
Micrometers
Forge with Digital Pyrometer
Hydraulic forging press
Air Hammer
Anvil
Hammers
Tongs
Several bench vises
Metal fab table
Solid workbenches
5 gallon quenching tank
Digitally controlled salt bath
Heat Treat Oven
Quench Plates
Buffers
Sand-blast cabinet
Air compressor
Variable DC Power Supply
Spectrometer for identifying metals
oxy/acetelene torch
arc welder
(MIG, TIG, etc)
lots of Hammers
Frink rotary platen
12" disc
Surface grinder
horz Mill
Drill PressES
several bench vises
lathe, turit
lathe, Engine
drill indexs numbered, frac, and lettered
Reamers
buffers
chop saw
sand-blast cabinet
air compressor
MIG welder
metal fab table
several solid workbenches
digitally controlled salt bath
forge
anvil
hammers
hydraulic forging press
lots of tongs
granite surface plate
height gage
calipers
files galore
optivisors
hand drills
leather working tools
boxes of abrasive paper
rows of belts
BOSS oscilating spindle sander
Dremel tool
56,000 rpm rotary tool
shoulder filing guide
sharpening stones
etching machine
utility sink
Air hammer
anvil 50# 100# 150# 200#
digitally controlled oven
belt grinder (KMG)
TIG welder
Sandblaster
LN dewar
9" angle grinder for grinding scale off damascus billets
low-temp salt bath
propane torches
propane cylinders (from camper size to 100 pounders)
table saw
wood chop saw
wood band saw
radial arm saw
water jet cutter
Pantograph
Engraving set-up with microscope
Tom Clark's new 180lb. Air Hammer
Nazel 2b and a Nazel 5b (for when I want to crush VW's like pop-cans)
Cyclone dust collector
High out-put flourescent fixtures with daylight bulbs every 3 feet on my ceiling
440lb Nimba made Anvil
Rolling mill
professional sword polisher that works for peanuts
drawers with heavy duty bb slides under all my workbenches
Tippman Boss Leather Stitcher
Heated,recirculating 10 gallon quench tank
30 gallon slack tub
30 gallon slack tub
"New Bass Boat
New pickup These are for stress relief"
