Hello, i'm new and i have a question, i use one of these vitorinox and i used to like it very much but sometime ago the blade started to jam and got impossible to open the blade. Can someone help to solve this problem? Im not american and not shure about some of the names u use, still if someone could give me some tips i'd apreciate it. Thanks.Less than six months ago I was carrying at least two knives. I carried a rotation of probably ten knives. But over the past two months, every time I put a knife in my pocket, I take it out and put the Alox Pioneer I got back in November in its place. It might change to a Huntsman when I go hiking, it might be supplemented with a Stockman while working or a Mora while bushcrafting, I might have a Classic on my keys, and I always have a Leatherman in my satchel, but the Pioneer is my carry 90-95% of the time. I would even say that 80% of the time I only have the Pioneer. It is just so perfect, I don't really need anything else. So, what the heck happened? How did this little metal handled scout knife do this?
[/URL][/IMG]![]()
It's very likely that the pivot just has a lot of dirt in it. It can happen especially with the oil they use when they ship from the factory. Typically, if you soak the knife in warm water with some soap until the blades loosen up. After a while, see if you can get the blade moving again. Work the blades around to get the dirt out and afterwards, let it dry and put a very light coat of mineral oil. I tend to also put the blade at an angle and wipe the back springs to clear up any dirt there.Hello, i'm new and i have a question, i use one of these vitorinox and i used to like it very much but sometime ago the blade started to jam and got impossible to open the blade. Can someone help to solve this problem? Im not american and not shure about some of the names u use, still if someone could give me some tips i'd apreciate it. Thanks.
I agree with you, but it has been voiced by some hardliners that SAKs aren't necessarily considered traditional because of the mass corporate production and the "cold" aesthetics.
I'll do it, see if i can get it back to use. ThanksIt's very likely that the pivot just has a lot of dirt in it. It can happen especially with the oil they use when they ship from the factory. Typically, if you soak the knife in warm water with some soap until the blades loosen up. After a while, see if you can get the blade moving again. Work the blades around to get the dirt out and afterwards, let it dry and put a very light coat of mineral oil. I tend to also put the blade at an angle and wipe the back springs to clear up any dirt there.
Best of luck!
Sometimes it's a problem with corrosion in the liners liners in the cellidor models. Moisture can cause the aluminum liner to corrode in a certain way that will freeze up the knife. This isn't a problem in the ALOX knives because the liners are either brass or nickel silver.I'll do it, see if i can get it back to use. Thanks
Gee, that reminded me of this pic!
If they would release a Cadet with a pair of scissors, now that would be near perfection!
