waynorth
Dealer / Materials Provider
- Nov 19, 2005
Maybe??two additional small pins on the mark side were used to attach a shield that had parted company
Waynorth, I could be wrong but I've seen and maybe have a couple Sheffield folders where the stag is not chased in, rather it sits flush ontop if that makes sense?Maybe??No sign of a recess in the stag though, that I can see.
When they do that w/o a chase, they usually find a flat area. If I am not mistaken that is a pretty gnarly area between the "pins". I could be wrong - that happens more than I'd like!!Waynorth, I could be wrong but I've seen and maybe have a couple Sheffield folders where the stag is not chased in, rather it sits flush ontop if that makes sense?
It is gnarly and would perhaps account for why it exited stage left at some point in the pastWhen they do that w/o a chase, they usually find a flat area. If I am not mistaken that is a pretty gnarly area between the "pins". I could be wrong - that happens more than I'd like!!![]()
That's some beautifully smooth-worn stag! Really lovely.Geirg
A classy item that Unchained , love a swedge terminating at a long pull. Sounds weird when you say that!
A new arrival I'm minding. It took a little work to make serviceable but the two of us are doing work all day together
I can find squat on the maker. No Thomas in Tweedale's. My guess this is Sheffield made for a company called J Thomas but that's a wild stab in the dark and await correction.
Either way it a very nice thing to use.
Question: should I reattach a shield or leave as is? I'm on the fence. I believe the original may have been oval.
Much like the lad who had to cut his arm off to escape being trapped by a rock you had to do that so it could once again be a useful tool as it was deigned to beThis Humason & Beckley (H&B Mfg Co.) 1852-1916 arrived last week.
It was in sad shape, with cracked bone and tips well-proud of the frame. I hated to remove so much steel, but there was no room to lower the blades.
Before:
After:
New lease on life!! Beautiful WabiSabi!!This Humason & Beckley (H&B Mfg Co.) 1852-1916 arrived last week.
Before:
After:
Much like the lad who had to cut his arm off to escape being trapped by a rock you had to do that so it could once again be a useful tool as it was deigned to beGreat work as always.
Thanks, guys! I assumed the main blade was originally a spear, but who knows? The edge was sharpened pretty straight, so it didn't take much work to sheepfoot it.New lease on life!! Beautiful WabiSabi!!
"imperfect, impermanent, and incomplete"! Nonetheless, Beautiful!!![]()
Gosh Rockman that's simply wonderful. Love that main and the bone is truly awesome. What's the walk and talk like? Have to ask, will you sharpen and use or just admire. Being a bonefide heathen you know what I'd do3 1/2" Schrade Cut Co. Original finish with a light patina, light use, the pen has a chip popped out of it, appears to have the factory edges, just not quite as sharp as a minty example. The typical near perfection buildand the mind boggling pick bone is just icing on the cake
Just staggering.the mind boggling pick bone is just icing on the cake![]()
What beautiful, bareheaded pickbone, guys!Same pattern, Rob , different blades!!
Most likely, that pick bone is pre-WWI, on both knives of course!!
Thanks, Duncan. I'm very pleased with it.R8shell that knife look sweet now. Neat ok Knife!
Thanks, EdGosh Rockman that's simply wonderful. Love that main and the bone is truly awesome. What's the walk and talk like? Have to ask, will you sharpen and use or just admire. Being a bonefide heathen you know what I'd do
Either way, well wear, a superb piece that would make any right minded person smile on seeing it.
Ps: can you date it accurately?
Beautiful HJSame pattern, Rob , different blades!!
Thanks, cudgeeJust staggering.![]()
Thanks, DuncanRob that’s a beautiful Jack with stunning Bone, Charlie adds the spice to all things nice!
Thanks, RachelWhat beautiful, bareheaded pickbone, guys!
Tight fit is right, that's beautiful and put together by somone very particular. Knew you'd know the where's and how's to date these things in order.Thanks, Edwalk and talk is crisp and snappy, I imagine it's the same as when new. Here's a picture showing the tight fit. As Charlie said it's most likely pre WWI but I believe the arched stamp harness jack he posted is earlier than this knife.
I won't be using this knife, I knew your heathen knife habits would force you to sharpen it and use it
Beautiful HJCharlie, I like the arched stamp, steel pins and rat tail bolsters
and of course the bone
Thanks, cudgee
Thanks, Duncan
Thanks, Rachel![]()
Pictures please!!!I recently came across a J Roberts knife pre dating his trip across the water where he and his buddies set up New York knife Co, funny to think his son may have made that very knife! That's is assuming I'm corre t in that they were linked to New York Knife Co in the distant past?
My knowledge or US cutlery is less than that of Sheffield's and my knowledge of that is less than what some of the experts here have forgotten, but I'm an eager student!
Oh yes a heathen is right, if I found Excaliber itself the first thing I'd do is bounce it off the stones till it shaved arm hair haha
Pictures please!!!
Everdays a school dayYou arrived at the correct place to learn more knife historyI've learned a ton from these guys,, learn something everyday
I'm with Charlie on the pictures please!
www.bladeforums.com
