Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
The Shiv is made of CPM 3V. It is an 8" stabbing weapon that is built to tolerate extremely rough use in demanding environments but is not so thick to not cut. It was originally developed as a combat knife but has also been popular with pig hunters.
THESE ARE SOLD, THANK YOU
The edge thickness before sharpening on these was .015" and it was sharpened at 20 degrees per side, so they are meat eaters. But you can still wail on it, you're not going to break it.
See video below.
The handle is ergonomically designed for a standard forward, reverse, saber and pinch grips for an average to relatively large hand. The tang is internally skeletonized. The scales are 3D sculpted CNC machined. The blade is made of ¼ 3V with a heat treat that has been optimized to maximize edge stability in insanely rough use. The blade has a swedge grind that creates distal taper and deep fullers that, together with the skeletonized tang, create a relatively light weight package (10.7 oz) that is supremely well balanced with thoughtful and deliberate distribution of mass that gives it a surprisingly light and lively feel in the hand without sacrificing tip strength.
The steel, Crucible CPM 3V, is a high performance particle metallurgy super steel with extremely high impact and torsional toughness. The heat treat has been tweaked to improve edge stability and edge retention. In this application it will easily tolerate abuse such as aggressive prying, punching holes in sheetmetal, cutting iron wire and even chopping through cinderblock. It is not stainless, but it has pretty good corrosion resistance.
Specs for the 8" Shiv:
CPM 3V, tested 59-60 HRC, .235 thick at ricasso
Total length 12.75
Edge length 7.5
Weight 10.7 oz
Extra grippy 3D machined scales
Black oxide treated 18-8 stainless steel fasteners
David Brown Kydex sheaths with TecLoc are custom made for these knives and are well designed and well made.
There is one 6" fighter and five 8" Shivs in this sale.
Rather than just take my word for it I made a video to illustrate the unusual durability of this knife:
[video=youtube_share;jAFQAp3Fo9I]http://youtu.be/jAFQAp3Fo9I[/video]
These are finish ground on the bevels, clips and flats. Scary sharp.
#1 is a 6" utility fighter. It is .165" at the ricasso and weighs 8 oz. It has black G10 scales machined in a diamond quilt. This is a good size for concealed carry and works well as a general purpose cutting tool. Video: https://youtu.be/IcovoTyGiRg $290 SOLD
#2 is an 8" Shiv in black micarta scales machined in a diamond quilt. $305 SOLD
#3 is an 8" Shiv in black micarta scales machined in a diamond quilt. $305 SOLD
#4 is an 8" Shiv in brown micarta scales machined in a diamond quilt. $305 SOLD
#5 is an 8" Shiv in black G10 scales machined in a diamond quilt. $320 SOLD
#6 is an 8" Shiv in black G10 scales machined in a diamond quilt. $320 SOLD
If you want a different sheath I have SpecOps Combat Master Sheaths in their standard colors. They are M.O.L.L.E. compatible and jump certified.
Shipping in the USA is $5.
These knives are unusual because they are machined. I do this in my shop on industrial CNC machine tools. A WIP thread documenting their construction can be found here: http://www.bladeforums.com/forums/showthread.php/1048443
I take paypal, cash, check or MO.
Thanks for looking,
Nathan
See video below.
Total length 12.75
Edge length 7.5
Weight 10.7 oz
Thanks for looking,
Nathan
