Great job, keep up the good work! Did you go straight from sanding to the glass bead? I have to use silica on mine first then the glass bead because my compressor is that powerful, it is spotty on the finish if I don't.
Went straight to glass Tim...in the past I did the two phases also, first silca than glass. I actually may try that next time, I had to spend alot of time with this one (might have to do with how freaking ass big it is) so as not to get the spotting you're describing. That and allowing my compressor to charge back up to 100psi...the blasting was worthless at anything less than 60psi. :grumpy:
