Introducing the dilemma:
Namely, the Sandrin Monza with the zirconium scales.
For those of you that have never heard of these.
I've actually had this one for a couple of days already, but I wanted to wait on the Spyderco before I make up my mind about anything.
My initial thought was that I unbox the Spyderco, appreciate it, and then send it back because of some minor detail that bugs me.
Because that Sandrin is every bit as impressive as advertised.
It's slim, but not so slim that there are any edges that dig in your hand (well, apart from the obvious one I mean).
The lock mechanism seems weird, but the people who handled one all seem to agree that it looks weird when it's presented to you and you go and think "That looks uncomfortable and also it might close on me when I grip it hard". Then you fidget around with it for five minutes and then you really like it. I was the same. Highly doubtful about it, I wanted to see that blade in person and had it ordered. The size is perfect. The ergonomics are perfect. The moment I found out that it works best for me when I use my index finger to push the lock, I realized that it can be used the same way the Bugout can be used - you can flick it open with the right timing so your wrist barely moves and you can flick it back, too - when you grip it right, all your fingers are out of the way and there's no danger of getting caught. That design makes it a true ambidextrous knife, like the Bugout.
The Zirconium feels great, this super fine milled texture really gives it a good grip and my hand gets a perfect four finger grip, yet again with no room to spare. the jimping on the spine of the blade follows a gentle curve that feels like your thumb is sitting down in a very expensive comfy chair.
The look of the blade is something you can either like or intensely dislike - I personally like it. The looks are all up my alley. The ergonomics are perfect for my hand size. The fidget factor is quite addictive - especially since the heavier metals that are used here provide a bit more oomph to the sound it makes when the blade hits the lock.
The clip is deep carry and it slides in and out of the pocket effortlessly.
What's not to like?
I only managed to find one immediate thing so far:
That kind of lock pushes against the blade inside the handle. When you push it back and rotate the blade, it travels as smooth as you'd expect a blade that runs on ceramic bearings would. However, when you use the intended (slow) way to open it,
it feels a bit scratchy.
Now this could be the blade or it could be the lock. If it's the blade, then this is permanent because I doubt the lock will be able to grind it smooth with time. If it's the lock, then it'll eventually get there.
And of course, there's the elephant in the room. This thing is made of tungsten carbide and has a whopping 71HRC hardness. That essentially means that all my means of sharpening a knife will fail against this.
S90V is tough to sharpen (for me) and Benchmade places the Bugout's steel at 60HRC.
This also means that it'll take a lot of time to dull. I think with my Bugout, I got about half a year of use out of the factory grind. I'm not very good at sharpening, so my own grinds don't last as long.
According to their numbers, a Sandrin blade will keep its edge around 5 times longer than a 'super steel' blade, which would mean I'd get about two and a half years before I need to worry about sharpening it - and with such a long time it can go without resharpening, I could really hand it off to a professional when the time comes.
