- Apr 9, 2004
brokenhallelujah said:Hm. Funny. Every single report by every single engineer who has spoken out about this has disagreed with that point. So have the ones that I personally know and respect. Jet fuel simply does not burn hot enough.
And a B-29 didn't take down the empire state building!
Just steering the thread a bit, fellers.
Dave Rishar said:Fair enough. Let us consider, however:
Boeing 767-300ER fuel capacity: 23,980 gallons.
Boeing 767 cruise speed: 540 miles per hour.
B-29 bomber (ballpark for all variants) fuel capacity: 5608 gallons. 9501 with external fuel tanks.
B-29 top speed (at altitude): 357 miles per hour. (It's reasonable to assume that it would have been travelling much more slowly than this at low altitude due to increased drag if nothing else.) Cruise speed was a leisurely 220 miles per hour.
B-29 weight, gross: 105,000 lbs. Max overload is about 130,000 pounds.
1 gallon of Jet-A, weight: 6.84 lbs.
Assuming a full load, a Boeing 767 is carrying about 164,000 lbs. of fuel -- more than the entire takeoff weight of a fully fueled B-29 (actually, more than the maximum overload weight of a B-29, for that matter), and would have been travelling a mere 200-300 miles per hour faster upon impact.
I will not go into the differences of construction between the Empire State Building and the WTC towers; it's sufficient to say that they were built with different philosophies in mind. Nor will I go into the differences in burning temperature between Avgas and Jet-A. I will, however, mention that when the Empire State Building crash occurred, most sources mention the fire being extinguished after 40 minutes. The fires at WTC were obviously quite a bit worse than this.
(Some sources mention a B-25 crashing, not a B-29. In that case, the plane would have been lighter, slower, and carried even less fuel. The B-29 is a worst-case scenario.)
Regardless, apples and oranges.
munk said:_! Does anyone remember F=M*A frrom high school physics? Essentially you have a 312,000 pound missle moving at the speed of a .45 ACP bullet. Except that instead of 230 grains, this one weighs 2 Billion, 184 million grains. That kind of puts it into perspective...!
Norm>>>>>>>>>>>>>>>>>>>>>>>>>>>
IT doesn't quite, Norm, because you didn't provide the terminal ballistic energy. I could look it up but I'm lazy and I don't know the BC of a Boeing Jet. You'd have to kinda ballpark the figure. How many foot pounds of energy? Anyway, a whole LOT of energy was 'imparted' to the twin towers, and everything you said about the engineers examining the attack event is exactly correct. (munk watches the discovery,learning and history channels all the time)
munk
brokenhallelujah said:And then what about building seven? Minor fires, no significant impact. Almost identical collapse pattern?
The_Shadow said:The part that always amazes me is this; The towers get hit, they fall, and almost instantly you started hearing about Osama Bin Laden and that he was behind it. Now, maybe I'm backward, but I had never heard the name Osama in my life before that time. It is puzzling to me how they knew at once who masterminded the attack, once it was done. No time lag, it happened right now. Then, they know Osama is in Afganistan and proceeed to blow the place apart. If they knew who dun it in minutes after the attack, don't you think they had some kind of idea what was going on before the attack? That is what makes me wonder.
