- May 19, 2006
wipe it off after use and it's fine.
Thanks for the tip!
Picked up a #8 Carbon at Courty & Fils, a fabulous knife shop near the Louvre in Paris last spring for 8.5 Euros. It lives in the picnic hamper now. To keep the wood handle from swelling and binding the blade, I melted a tablespoon-sized pat of hard floor wax (Johnson) into the blade groove with a heat gun. That sealed the wood and it hasn't gotten stuck since. That thin blade takes an awesome edge.
When my carbon no. 8 gets wet and swells, I pull harder to open it. Once it dries, I no longer need to pull harder.
-- Mark
I need to give this a try. I've tried petroleum jelly to no avail. Thanks for the tip.
As far as EDC goes, as Opinels get smaller the blades get thinner as well as shorter.
If you modify an Opinel you can shorten the handle a little easily, and also shorten the blade slightly by taking the flimsy tip off and making it a drop point.
A #8 is just a little to big for EDC. A modified #8, or maybe a modified #7, is perfect.
I avoid the swelling by soaking the whole knife in mineral oil for at least a week. It helps to dry it a bit in a hot car or another hot dry place for a day or so first.
Not my pic, do a search for "Opinel mods" for a world of ideas.
No, as a practical matter it doesn't really evaporate under typical conditions.Washes away, maybe. And long term is relative. The fact that it doesn't require a complicated application makes it more likely it will be maintained and re-applied.mineral oil evaporates - so it doesn't provide any long term protection.
Cures isn't always what you want. Mineral oil is food safe, which is why it is widely used on cutting boards and wooden cooking utensils.walnut oil cures and is food safe.
I just stand an open Opi up in a glass of mineral oil to get more in the slot. I have put a closed knife in a jar of oil (mineral, motorCan you elaborate on the mineral oil bath? Do I just take the closed Opinel and submerge it in the oil for a week, then dry it afterwards?
